air con leaking
2.7 V6 30v biturbo - 251bhp
2.7 V6 30v biturbo - 261bhp
s4marsh
air con leaking
Post by s4marsh » Tue Jul 07, 2009 1:07 am
my air con has been leaking for a while but it only leaks while using it on cold untill the pressure drops low enough for the compressor not to kick in it still had just under the lowest operating pressure the other day when checked indicating its not leaking all the time,,,very strange. i've added some dye and oil but any suggestions what the problem could be?
Blue_Thunder
RE: air con leaking
Post by Blue_Thunder » Tue Jul 07, 2009 7:57 am
I think the threaded bits on the compressor which the hoses attach to can break away. I've had no aircon since one of my many engine pulls. :-(
s4marsh
RE: air con leaking
Post by s4marsh » Tue Jul 07, 2009 4:02 pm
Thats worth a look at thanks, and maybe using ptfe tape on all the connections. i had a pipe replaced a few months back down behind the headlight area they said, but it never solved the problem its had around £320 spent including 2 regases+dye and its still leaking. its going back in as soon as it stops running cold but if they think i'm giving them any more cash they're gonna be dissapointed surely they should have pressure tested it although it does keep pressure while its not running.i dont want to fill it with that leak stop stuff as i'd much rather have a proper fix
Blue_Thunder
RE: air con leaking
Post by Blue_Thunder » Tue Jul 07, 2009 10:22 pm
Leak stop stuff?? Tell me more. I'm dying with no A/C at the moment.
s4marsh
RE: air con leaking
Post by s4marsh » Wed Jul 08, 2009 12:52 am
yeah it comes in a can and you just add it to the system like the gas try auto-cool or there's plenty of other in the uk it'll cost you 40quid to recharge and leak stop it. try here http://www.car-air-conditioning-supplie ... php?cat=30 even halfrauds might sell it for about 10 zillion pounds
s4marsh
RE: air con leaking
Post by s4marsh » Wed Jul 08, 2009 12:59 am
i've just found some on e bay for 8.99
Blue_Thunder
RE: air con leaking
Post by Blue_Thunder » Wed Jul 08, 2009 9:06 am
Just seen it only repairs leaks in the rubber/plastic components. Think mine is a crack in the thread on the compressor. :(
Users browsing this forum: No registered users and 62 guests
