You had me worried for a moment therePorky wrote:Oh definitely, it's really only the last mile where the road opens up to a straight, national speed limit road, by which point the engine is warmed....don't panic!!
Highest MPG achieved & Lowest!
- PetrolDave
bingboybri
slightly off topic guys but im thinking seriously about getting an rs4 but it will be my wife who drives it 90% of the time for work but her work is only at wort 2.5 miles from home........ would this be seriously bad for one of these as i have a 330d just now and i know its not doing the old oil burner any favors at all!!!
bingboybri
- PetrolDave
bingboybri
just taken ownership of my RS, seeing 29mpg on average DIS (dont bother with live read out) setting on my daily motorway jaunt...23 miles with another 12 miles in total on A roads....but I never gun it for the 1st 5 miles really....infact I only have a few little red line blips on my daily run, because I take it easy up to the motorway, then drive at 60mph due to average speed cameras on on the m'way and then like to run her gently before switching off at my destination..! Is this the right approach guys? what sort of oil temp do people open their RS's up at and switch off at? hate the thought of coking or other temperature related damage... hope this isn't highjacking...it seems to be in keeping with the thread
R32 used to be around 31-32 on the motorway stretch so I am well chuffed at the RS!
07/57-B7 RS4 Saloon-Sprint Blue,Tech Pack, DRL's,Bluetooth,Carbon Trim,Chrome Optics,Sunroof,open zorst flaps,FBSW,Bose,Buckets,New Boots,R8 alu oil cap,BMC panel,RS plate,Fresh plugs,10mm Rear H+R spacers courtesy of Virdee.
Also - 1970 MGBGT for Hillclimbing and Sprint racing
03/53 - MK4 Deep Blue Pearl R32 3 door (sold)
"You never hear a truer word spoken in jest"
Sounds like you are being plenty easy on her. Display tells you not to exceed 7000rpm until oil goes over 60oC so you should be okay. These cars are moving pretty quickly by 7000rpm so Audi must be pretty comfortable at that engine speed from cold.
On the cool down, this is more important on high performance turbo's, I used to let my STiPPP idle for a couple of minutes if I had been driving hard, or i would drive easy for the last 5 minutes of the journey
One thing to remember with big brakes is not to sit with you're foot on the pedal if you have just been working them hard as this will cause warping due to the size of the caplipers and pads and the heat being focused for to long on one part of the disk
Great cars, even driving slowly
- PetrolDave
cheers Les (used to let my MR2 tubby cool down too for a good 5 mins) - I feel that 7000 is crazy, I'd never rev the R32 upto 7k when cold!!
1) because the limiter kicked in at 6700 LoL
2) the thought of the pistons n crank being worked hard 5 mins into a long haul when nothings lubed
just grates me!
I like to warm her up first - aaiiiaght! the rewards are worth it
I fear warping the brakes too so thanks for the tip!!
good robust tank like German engineering on the one hand, fragile expensive moneypit if ill treated or not respected....
nearly home time...
(puts on biggles goggles)
tally ho
nearly home time...
tally ho
Users browsing this forum: No registered users and 367 guests
