Standard Airbox De-flap
caldy
Post by caldy » Wed Jun 17, 2009 10:01 pm
Had a spare hour or so this evening and after browsing various forums, particularly US based, decided to have a go.
Bit of a ball-ache and a few bruised knuckles but, half an hour later, all done and working fine. No need to remove the front bumper and yes, you can reassemble with the 'horn' but there is a trick involved!
I removed the flap altogether but replaced the solenoid, actuator and vacuum line. The trick is merely to reassemble the solenoid and vacuum line and put it down behind the headlamp assembly, out of the way of the airbox. Drop the airbox down and then by feeling 'out' through the airbox into the horn, pull the horn onto the airbox until it clicks into place. Voila!
Off to the RR at Northallerton with Graeme this Saturday so we'll see what it's like.
RS4 B7 Phantom Black
sonny
RE: Standard Airbox De-flap
Post by sonny » Wed Jun 17, 2009 10:54 pm
Have you noticed any benafits by doing this mod, WOULD you advise it as a worth while?
caldy
Airbox
Post by caldy » Thu Jun 18, 2009 6:57 am
Dunno - doesn't seem as if it can do any harm.
Anything that gets air into and out of the engine more efficiently should be a good idea. I already have done various things to aid this process and short of a Gruppe M or similar, this seems to be a sensible mod. Cost is free, unlike most things on an RS4!
Cannot discern any increase in induction noise, probably because of my exhaust overpowering everything else. Still, let's see on the dyno.
richib86
RE: Airbox
Post by richib86 » Thu Jun 18, 2009 9:40 am
hey caldy, i did this mod on my car with a k&n drop i filter and i can def hear more noise(nice noise ha). could you share a little more information on your de-vaned inlet manifold. i have a new manifold on the way to get ported a little, curious about your mod
2007 rs4 mugello blue premium package, sirius, black optic grill, miltek non-res non-valved catback, milltek dp's, stasis/alcon clutch, bodymatched reflectors, tints, xenon interior bulbs, KW V3, 10mm h&r spacers, REVO flash, K&N drop in filter, euro steering wheel, jhm short throw,De-Flapped, ac glove mod, IMA multimedia adapter, h-sport sways, some alcantra on the way :)
caldy
Inlet vanes
Post by caldy » Thu Jun 18, 2009 9:45 pm
Whilst polishing my inlet manifold, all I did was remove the tumble vanes from the shafts in the inlet manifold and the separator vanes in the top of the cylinder head. It was my understanding that these were to aid low down torque at start up and to control emissions. In my view, they were an interference to air flow which would limit power.
Oli
RE: Inlet vanes
Post by Oli » Thu Jun 18, 2009 10:01 pm
Got any pics of your car - I haven't seen a carbon bonnet on an RS yet!
P_G
Post by P_G » Thu Jun 18, 2009 10:06 pm
Should have some pics on Saturday when we are all at our Northern r/r meet.
caldy
C/F Bonnet
Post by caldy » Fri Jun 19, 2009 7:31 am
klauster
RE: C/F Bonnet
Post by klauster » Fri Jun 19, 2009 8:09 am
that looks ace :D
P_G
Post by P_G » Fri Jun 19, 2009 9:49 am
Looks even better in the flesh. 8)
klauster
Post by klauster » Fri Jun 19, 2009 12:46 pm
i dont wanna see it... it will cost me more money :(
Ozrs4
Post by Ozrs4 » Mon Aug 10, 2009 12:49 pm
Hi P_G, did you end up doing the RR and found any noticeable improvement with the airbox de-flap mod? Did you remove the air horn as well or just de-flap?
btw, your CF bonnet looks great. Mine is phantom black too and can do with one like yours. How much lighter is it compare to oem bonnet?
Thanks.
2007 RS4 B7 - Phantom black saloon
Ozrs4
Thanks.
Users browsing this forum: Bing [Bot] and 305 guests
