MRC vs. Pippyrips B7 RS4 - The build-up strikes back!
I just pulled my breather hoses off...almost bone dry...I was actually surprised...I expected oil to drip out...
there is a baffle built into the valve cover also...
you could put a baffle/seperator on each cover, or where the hoses join...
problem is, any oil is entrained, a mist, and may pass...perhaps a charcoal filter type...
something like this on each valve cover... http://www.mahle.com.br/C125705E004FDAF ... 3329WEBBEN
the M3 drops it right into the manifold in front of an intake runner...
below it is a sump and drain hose with check valve that goes to the sump
the valve opens upon loss of vacuum, ie, when car is turned off, allows the accumulated oil to drain into the sump...
I'm beginning to think the deposit problem is related to the ambient temperature and ethanol level in the fuels. Most of the severe intake valve deposits cases I've heard of have been in cold winter climates. High levels of ethanol oxygenate ("contaminants") are also used in these climates in the winter. Ethanol blending is not precise in many regions. In some cases it is close to 20% of the fuel.
So my car is now back home safe and sound.
The inlet tract is squeaky clean once again and the solution that will hopefully put an end to this issue is on the car.
Once again my thanks go to Doug & MRC - I really can't recommend them enough.
While the car was there she also received a set of adjustable H&R front & rear anti-roll bars for good measure - I drove back in heavy traffic so the roads didn't open up until the end of the journey but first impressions are the car is stiffer & more level in the bends. Change of direction is also a lot sharper now. The front bar is set to soft and the rear to stiff to helppromote over rather than under steer. I hope to get out for a few hours over the week so will give a better review soon.
But the final mod to be done on this visit and possibly the best one I’ve done to date - Doug removed the amber 'egg yokes' from the front lens - it makes so much difference to the front end, especially phantom black
Oh excellent news bud, and what is this device (solution) that's will put a end to the build up (if it works they will have a lot of custom ahh).
When they removed the orange lenses what dd they replace them with, iv been thinking of doing this too for some time now.
- spikeyoldbiker
- 1st Gear
rob, i am looking to do this too..cheers mate
Sounds interesting would be keen to have this done if it solves the problem, so the bulb could be done diy then??
2018 B9 RS4 Navarra Blue
2013 B8 RS4 Sepang Blue
2007 B7 RS4 Avant Sprint Blue
2001 B5 RS4 Nogaro Blue
1993 B4 S2 Avant laser Red
Users browsing this forum: No registered users and 159 guests
