As most of you will know, part of their original work involved taking of the inlet manifold and cleaning all of the oily, baked on crap that had covered all of the inlet valves, tract & manifold. By the time they were finished all was squeaky clean and shiny :
The plan was always to open her up again after covering some decent mileage to measure how much build up, if any had re-occurred since, before attempting to cure the problem once and for all.
Doug & the team set about doing so today. The following pictures are a selection of what they found:
To be honest after seeing the original pics of build-up after 20k miles, you could be excused for thinking what has occurred since isn’t that bad,…but when you consider the car has only done 10% of the mileage since…………
As you can see the valves are already starting to become covered again, and if you look at the pics of the inlet manifold, you can see trails of oil that came out of it as the guys turned it upside down – it was literally dripping over the floor!
The guys have since set about cleaning everything up again before modding the car to hopefully avoid the build-up happening again – if all goes to plan I should have the car back on Wednesday
Thoughts and opinions on the findings welcomed…..
