New Discs and pads required....keep standard or upgrade??
2.7 V6 30v biturbo - 380 bhp
RS4Ralph
Post by RS4Ralph » Mon Jun 08, 2009 8:29 pm
I need to replace discs both front and rear along with front pads (the rear pads are ok). The cheapest quote I've had so far including fitting is £ 1255 for OEM AUDI replacement parts!!
Apart from the B7 upgrade and factoring in costs, what would be my most economical solution here? There's no room for skimming the discs either, so that's out.
Does anyone in the group have good condition discs front and back discs they would like to shift my way for the right ££.
Thanks,
Stan
don
Post by don » Tue Jun 09, 2009 8:04 am
I was quoted $270 AUS each for DBA B5 RS4 slotted discs in 4000 series from Race Brakes Sydney.
http://www.racebrakessydney.com.au/disc_rotors.html
They are one piece but still excelent value at approx £135 a side and well worth considering for normal road use if you are on a budget. Given they are one piece you can always machine them down the track and so they should last longer.
I think DBA also ship international though I'd expect postage will add another £50 or so.
http://www.dba.com.au/2006/products_4000.asp
I think there are some UK sites selling these as well but probably cost more.
For pads, raceshopper is the cheapest place I've found for Ferodo DS2500 pads at $312 US for a complete set of B7 RS4 front pads. Should be cheaper again for the B5 pad set.
http://www.raceshopper.com/ferodo_compounds.shtml
gareth215
Post by gareth215 » Tue Jun 09, 2009 9:37 am
Hi, I would get some B7 8 pot calipers £500 ish 2nd hand or about £750 new, then some B7 discs for £450 (PW Motorsport)a pair and I can supply B7 pads for £79.00 (I got a number of sets at the right price and put them on ebay as a buy it now!) so total price is £1000 - £1250 but then you will get to sell you old calipers discs and pads for at least £200 even if they are worn as they are a popular upgrade for lesser Audi / VWs.
So it will work out a bit cheaper if you source the parts carefully and you get much better brakes!
That is what I did anyway.
B5 RS4 in Avus, Custom 3" down pipes 100 cell cats, MRC custom map, ITG filter, HR antiroll bars, Poly bushes, B7 calipers and discs, ESP DTS, TV, Sat Nav and sun roof.
derdle
Post by derdle » Tue Jun 09, 2009 12:48 pm
I think it all depends on how you drive your car. If you use it (or intend to use it) on a track then maybe you ought to consider an upgrade. If foe purely road use then stick with the OEM stuff. Rememebr, if you go with an upgraded system the pads and disks will cost more each time you need to change them (as compared with the stock brakes).
I'#m sure you can source the OEM discs and pads cheaper than that - shame VAGPARTS has gone, how about GSF?
Don, I thought the DBA brakes were a two piece item, so all you had to do was repalce the rotor when they wore out, rather than the whole disc? I looked at these as an option for my car, but they don't do anything for the RS6+ brake system!
RS4 in the only colour to have - Misano Red | MRC Remap | RS6+ brakes | H&R and Custom Performance Parts suspension |
Huge Grin :biggrin3: If you dont "do it now" you never will.
Rs4Fan
Post by Rs4Fan » Tue Jun 09, 2009 2:54 pm
If you are not going to the track frequently, I would stick with the OEM stuff. Pads can usually be bought cheaper in the US.
'00 S4 (sold)
'01 RS4 (sold)
'93 964RSA
'94 964 Turbo
'08 E63 AMG
'10 Cayenne GTS
R5CPK
Re: New Discs and pads required....keep standard or upgrade?
Post by R5CPK » Tue Jun 09, 2009 11:10 pm
[quote="RS4Ralph"]I need to replace discs both front and rear along with front pads (the rear pads are ok).
You can't change the discs and not the pads. You'll never get full efficiency as they will have worn to fit your current discs..
2003 8L Audi S3
2007 B7 Audi RS4
1998 B5 Audi S4
2004 B6 Audi S4
2000 8L Audi S3
2001 B5 Audi RS4
don
Post by don » Wed Jun 10, 2009 4:37 am
The 4000 series in DBA are a one piece disc. The DBA 5000 series are two piece with alumiinium hat, a very nice disc but don't think they are available for the RS4.
I just noticed these on ebay.uk but auction still has a way to go but you could be lucky:
http://cgi.ebay.co.uk/ws/eBayISAPI.dll? ... 0405045821
frazered
Post by frazered » Wed Jun 10, 2009 9:34 am
RS4Ralph
Post by RS4Ralph » Sun Jun 14, 2009 9:37 pm
Guys, thanks for the tips on the discs from DBA. I've sent an inquiry off to them and hopefully I can get a number for the Clark Motor sport lot in Scotland. I'm off on holiday shortly, so could order these and get them put on when I get back...
My rear discs are shot too, do you recommend I just get the OEM parts for these or do DBA also do them?
Thanks guys,
Stan
Users browsing this forum: No registered users and 104 guests
