Clutch stop for RS4?
sonny
Post by sonny » Mon Jun 08, 2009 10:30 am
Any body know of any companies that produce a clutch stop for the the RS4?
Ozrs4
RE: Clutch stop for RS4?
Post by Ozrs4 » Mon Jun 08, 2009 11:43 am
Sorry to be ignorant but what is a clutch stop?
2007 RS4 B7 - Phantom black saloon
sonny
Post by sonny » Mon Jun 08, 2009 1:09 pm
Cars with manual transmissions (excluding paddle shift technologies like SMG or DSG) have clutch pedals with tons of "space" between the floor and the actual pedal. This requires the driver to learn where the engagement point is on the car. A clutch stop reduces this unnecessary "space", allowing the driver to adjust the ideal point of reference where the clutch pedal stops just after the clutch mechanism disengages. Basically, this translates into quicker, cleaner, smoother shifts.
Most cars have a Clutch stop (buffer) built in however these can be replaced with the said items, I have seen them placed in others cars esp for track use.
b7rs4saloon
Post by b7rs4saloon » Mon Jun 08, 2009 6:22 pm
Sounds like a good idea.
Especially in a car with a crap clutch like teh RS4...
sonny
Post by sonny » Mon Jun 08, 2009 7:21 pm
Well I was looking into short shifts for the car, and then remembered about the clutch stop upgrade, I know they are popular on tracked BMW, My friend had one in his M3, and he said it totally changed the way he drove, when you dip the clutch it only goes down as far as the biting point, this enables you to be rather aggressive/quick on the gear changes with even having to worry about the location of the engagement point. it does however feel strange when you first start to drive with it, you need to build confidence.
ghoonk
Post by ghoonk » Mon Jun 08, 2009 7:44 pm
So, a good idea then -- does anyone know if the clutch position is adjustable?
2006 Sprint Blue Audi RS4 : photography by lifegauge
Ozrs4
Re: RE: Clutch stop for RS4?
Post by Ozrs4 » Mon Jun 08, 2009 10:34 pm
ghoonk wrote:So, a good idea then -- does anyone know if the clutch position is adjustable?
One would think it has to be adjustable unless it's made specifically for RS4 and even that I think every RS4 will have a slightly different friction point.
Question is : will the use of clutch stop have detrimental effect on the clutch itself long term since you only depress the clutch stopping just at / below friction point? I guess not but can Sonny clarify? Thanks.
sonny
RE: Re: RE: Clutch stop for RS4?
Post by sonny » Tue Jun 09, 2009 8:48 am
@Ozrs4: I don't know the answer to that question, I would at a guess say not, as the clutch clears the biting point, its set a few millimeters below biting point.
OK this is a thread over on e46Fanatics ref the clutch stop http://forum.e46fanatics.com/showthread.php?t=206363
Also http://www.uucmotorwerks.com/html_produ ... /about.htm
Just want to point out that this is primary a BMW mod, Not sure if modern Audis have them, any one confirm?
Ozrs4
Post by Ozrs4 » Tue Jun 09, 2009 8:53 am
Thanks Sonny. One more thing came to my mind is will the clutch stop prevent us from starting the engine if the clutch is not "fully" depressed?
sonny
Re: RE: Re: RE: Clutch stop for RS4?
Post by sonny » Tue Jun 09, 2009 9:01 am
Ozrs4 wrote:Thanks Sonny. One more thing came to my mind is will the clutch stop prevent us from starting the engine if the clutch is not "fully" depressed?
:oops:
Totally forgot about that, well that's that mod out the window then LOL
Not sure how far the clutch has to be down!
Ozrs4
Post by Ozrs4 » Tue Jun 09, 2009 9:59 am
[quote= Not sure how far the clutch has to be down![/quote]
Well, I checked it and it has to be pretty much fully depressed in order to start the engine. Oh well, it was a good thought.
sonny
RE: Re: RE: Re: RE: Clutch stop for RS4?
Post by sonny » Tue Jun 09, 2009 11:31 am
Yes while it lasted, Taxi for Sonny.
b7rs4saloon
Post by b7rs4saloon » Tue Jun 09, 2009 5:48 pm
Surely moving the switch or bypassing it should be easy...?
Users browsing this forum: No registered users and 437 guests
