Got the Modifying Bug Again!
sonny
Post by sonny » Sat May 30, 2009 5:39 am
I would be interested if it was confirmed that it would def pass its emission test come MOT time, have you had a MOT pre check for emissions?
pippyrips
Post by pippyrips » Sat May 30, 2009 7:49 am
Emission levels are controlled by the cats which remain entact, I can't see any problems come MOT time.
P_G
Post by P_G » Sat May 30, 2009 9:20 am
As Rob said, as there is nothing done to the cats and it is essentially a cat back modification there is not effect on emmissions.
sonny
Post by sonny » Sat May 30, 2009 3:03 pm
OK but has it been confirmed that it will pass ts MOT?
Oli
Post by Oli » Sat May 30, 2009 5:48 pm
I run an MOT testing centre, and I can assure you, just changing the pipes rear-ward of the CATs and the Lambda sensor's, will have little or no effect on the emissions result
P_G
Post by P_G » Sat May 30, 2009 6:09 pm
sonny wrote:OK but has it been confirmed that it will pass ts MOT?
It's going in for its MOT in two weeks, I'll let you know then.
sonny
Post by sonny » Sat May 30, 2009 8:58 pm
Ok cool, well I hope so, and I will look forward to it passing with flying colours, if so then I may well do this mod too!
rAudiguy
Post by rAudiguy » Sat May 30, 2009 9:21 pm
I wouldn't worry about the pipes making you fail, it's the dreaded DRC that is more likely too.........lol
Current car..... hmmmmm????
RS4 B7 Gone
RS6 C5 Gone
M3 E46 smg Gone
S3 Gone
P_G
Post by P_G » Sat May 30, 2009 10:13 pm
I'm not worried Jim having had a fully modified S4 with 200 cell cats and s/s full system that passed emmissions, this car isn't going to be any different. But for Sonny's peace of mind I can show this to be the case at MOT time.
davefaedeen
Sound clips
Post by davefaedeen » Mon Jun 22, 2009 9:45 pm
Hi PG
I know this is an old tread but i was wondering if you have any sound clips of the AAS Xpipe, i just got an RS4 and i want more noise, just cant seem to justify spending 1600 on a miltek system and the AAS system (cash wise) seems to be the way forward!!
P_G
Post by P_G » Mon Jun 22, 2009 10:53 pm
I tried to record it but the equipment I had was limited and got more background noise than anything else.
gogsyp, Klauster or caldy would be able to vouch for what is sounds like (I hope!)
davefaedeen
Post by davefaedeen » Mon Jun 22, 2009 11:39 pm
cheers PG so u think its worth doing!!!
P_G
Post by P_G » Tue Jun 23, 2009 12:47 pm
It has been for me and I love the throttle lift off pop the exhaust makes too. Put it this way it is circa £300 and if you don't like it you can just put your centre resonator section back on!
Users browsing this forum: No registered users and 195 guests
