In the last couple of days, my DIS has been showing a warning for the windscreen washer.
I have obviously topped it back up, especially how the roads are at the moment, but the warning light has remained on.
It's bloody annoying [img]images/graemlins/mad.gif[/img]. Help!
Problem with DIS Warning
Re: Problem with DIS Warning
i also had this and found the washer pump was faulty, leaking washer fluid
So you either have a faulty washer pump, or a faulty leve sender unit
VAG COM might find the fault????
Can't beat a bit of boost!
I've had the same thing, new washer pump for the lights fixed it, changed under warranty on my RS4.
Even without the leak they sure use some fluid this weather!
Hope this helps!
Hope this helps!
Users browsing this forum: No registered users and 36 guests
