Manifold rattle on facelift S4
S4_Biturboz
Hi there, I've been informed that the manifold rattle that is a common issue for pre face lift S4s has taken up residence in my facelift S4. Is this one of the turbo manifolds that need replacing? If so do you have any advice as to which one I should replace it with. Thanks in advance!
RE: Manifold rattle on facelift S4
just check the heat shields first if not replace with rs4 seems to be as good results as many aftermarkets with a bit of flowing work
Blue_Thunder
- Top Gear
The RS4 maniolds are the same as the facelift manifolds.
Have you been quoted for the work? IIRC it's an engine out job, so you're probably looking at £1000+.
As Andy has said, you should rule out the heat shields incase they are rattling.
If it does turn out to be a manifold and the engine does need to be pulled, there are a number of other parts which are generally advised to be changed whilst it's out.
MarkHanman
Users browsing this forum: No registered users and 170 guests
