Slight vibration through the acclerator pedal???
mattler
Post by mattler » Wed May 20, 2009 9:16 pm
When cornering hard in my RS6 I feel a vibration through the gas pedal as if it were somehow mated to the suspension??
Is this normal, if not opinions?
Matty
Rupert
RE: Slight vibration through the acclerator pedal???
Post by Rupert » Wed May 20, 2009 10:00 pm
Yes, it's normal, especially if you still have DRC.
Cornishmoocher
Post by Cornishmoocher » Wed May 20, 2009 10:12 pm
Varying opinions as to what causes this- from drc, air in the break system to worn bushes on the pedal, could be either or all or none, but it is common !
Me, I prefer a tight bush.....
It's all Bollox.
Hartge
Post by Hartge » Thu May 21, 2009 12:17 am
Yep, its normal.
A lot of it is to do with 450+ hp passing through a very large car with Audi's dreadful DRC (worse in the Avant with such a large shell vibrating).
I noticed it was really bad on a RS6+ with the 10mm lower spring drop, but amazingly now that my DRC has been replaced with coil-overs I hardly ever experience it any more.
Big tip - ditch the DRC as soon as you can.
onlinesys
Post by onlinesys » Thu May 21, 2009 12:59 pm
Hi guys,
I have the same issue after replacing the DRC to H&R coilovers and have the car lowered a bit. It mostly happened on bad surface when I was corning. Glad to hear it is normal (well to a certain extent).
iaingbrown
Post by iaingbrown » Thu May 21, 2009 10:54 pm
Normal...but very odd sensation. Feels like the judder from ABS brake on my former Subarus kicking in but happens on the go pedal rather than the stop pedal. Had it fer 3 years no better and no worse for it. Roads are much poorer and get it more often but that's another topic.
Cornishmoocher
Post by Cornishmoocher » Fri May 22, 2009 12:03 am
my old b6 did it too......
It's all Bollox.
ataRS6
Post by ataRS6 » Sat May 30, 2009 3:55 am
mine done it too, brake pedal bushes very common
RS6 Avant, black with black wheels, front S6 led lights, rear smoked Led lights, miltek non-res, miltek cat by-pass down pipes, ITG air filters, H&R kit with Arb's, MRC stage 2
Users browsing this forum: Bing [Bot] and 31 guests
