vag-com!!!
fade2grey
vag-com!!!
Post by fade2grey » Thu Nov 13, 2003 1:09 pm
Right, it's arrived. But.. what can I do with it? before I get around to reading the manual someone tell me something interesting I can do with it straight away! [img]images/graemlins/smile.gif[/img] please..
A
98/Missano/Bose/Carbon
Nige_RS4
Re: vag-com!!!
Post by Nige_RS4 » Thu Nov 13, 2003 1:21 pm
Plug it in, select the turbo module and increase the angle of the compressor wheel blades from 23deg (default) to 45deg - this will release an additional 35bhp [img]images/graemlins/jump.gif[/img]
Only kidding !
Try carrying out a TBA -
Select]
[01 - Engine]
[Measuring Blocks - 08]
Enter Group 060 [Go!]
[Switch to basic settings]
Enjoy !
https://www.speedcams.co.uk
B5 2.7t S4 - gone
B5 2.7t RS4 - gone
Ed 30 Golf DSG - gone
2018 Golf R 7.5
Dippy
Re: vag-com!!!
Post by Dippy » Thu Nov 13, 2003 1:37 pm
Apart from TBA, it's main use is to check for DTCs.
You can also do some reprogramming of the central locking.
After that you can do more diagnostics by logging key values such as boost, MAF, torque etc.
2001 Silver S4 Avant
fade2grey
Re: vag-com!!!
Post by fade2grey » Thu Nov 13, 2003 1:55 pm
Cool stuff.. I'll have a play & let you know when I blow it up!
Carps
Re: vag-com!!!
Post by Carps » Thu Nov 13, 2003 2:07 pm
My favourite is logging block 115 on the engine. This gives you the turbo boost details. Other good ones are 121 (IIRC) which will give you torque. From this you can import the data into a spreado and see what kind of power you are making [img]images/graemlins/thumbs.gif[/img]
DavidT
Re: vag-com!!!
Post by DavidT » Thu Nov 13, 2003 6:37 pm
Is there a measuring block for oil temperature ?
Carps
Re: vag-com!!!
Post by Carps » Thu Nov 13, 2003 7:42 pm
Yes. Everything you see on the instrument cluster is avaialble - plus a whole load more. Best thing to do is plug it in and take a browse. I have never found it documented anywhere what is available - you just have to cycle through each block. If you see some that are empty as you run through, don't assume that is the end as I did to start with. Just keep going (upto 255, IIRC)
sitas3
Re: vag-com!!!
Post by sitas3 » Thu Nov 13, 2003 10:39 pm
remember chaps, for those that are remapped, that there is a restriction on measuring boost above 1.5 bar - ecu/boost sender unit restriction apparently. [img]images/graemlins/thumbs.gif[/img]
M3 CSL - Silver Grey, a few options.
Paul-RS
Re: vag-com!!!
Post by Paul-RS » Thu Nov 13, 2003 11:25 pm
that will be the MAP (manifold air pressure) sensor that doesnt go above 1.5 bar then.
DavidT
Re: vag-com!!!
Post by DavidT » Fri Dec 12, 2003 11:42 pm
Carps mate,
I cannot get an oil temp reading out of VAG-COM, do you know how to do it please ?
(I want some objective figure as I make vaious engine mods)
Cheers,
David
Carps
Re: vag-com!!!
Post by Carps » Sat Dec 13, 2003 11:01 am
David,
select the Instrument Cluster and chose the 'measuring blocks' option. The select group 050. You should see two temperature readings (the last two columns). The first is Oil Temperature, the second is coolant temperature.
Have fun...
DavidT
Re: vag-com!!!
Post by DavidT » Tue Dec 16, 2003 3:07 pm
Thanks Carps, works a treat.
Dunno how I managed to miss it when I searched [img]images/graemlins/062802drink_prv.gif[/img]
Golich
Re: vag-com!!!
Post by Golich » Tue Dec 16, 2003 8:13 pm
Na that's not right. You can measure your boost no prob. Well I did on my AMD chipped S4.
Return to “Electrical”
