rs4 down on power......i have a maf reading..
2.7 V6 30v biturbo - 380 bhp
maxrs4
Post by maxrs4 » Mon May 18, 2009 7:02 pm
i rolling road'd the rs4 and got 395, got told i should have 450 ish from the last owner, it was running a bit rich, i checked the air filter and it was blocked to crap! so i have a new one and its running much better but should i be concerned i got a reading of 351.7 gs as i hit the limiter in second but im not sure what it should be! or even how to do the readings properly. i could get a print out of the car if it helps!!
thanks for you help in advance im new to the vag world!!
neckarsulm
Post by neckarsulm » Mon May 18, 2009 7:06 pm
g/s is .8 bhp (roughly)
so divide 350 by 4 then time by 5
87.5 x 5 = 437.5 bhp (approx)
If the last owner talks bhp but has a blocked air filter I'd take his estimate with a pinch of salt :)
maxrs4
Post by maxrs4 » Mon May 18, 2009 7:28 pm
neckarsulm wrote:g/s is .8 bhp (roughly)
thanks, the last owner was genuine enough and it is due a service anytime now. if its 437.5 ish a propper service might get it near on the 450 ish
how is it your know maf gs = bhp power ?
neckarsulm
Post by neckarsulm » Mon May 18, 2009 8:37 pm
I'm not sure where it originated but it seems to be quite accurate.
Anyone know?
rtd
Post by rtd » Mon May 18, 2009 8:47 pm
is it possible to check if MAF is working properley with VAGCOM, if so could someone explain how please.
Volvo XC90
C7 - RS6
C6 - RS6
B5 - RS4
Nige_RS4
Post by Nige_RS4 » Mon May 18, 2009 9:07 pm
rtd wrote:is it possible to check if MAF is working properley with VAGCOM, if so could someone explain how please.
Yes, but you either need a known good log or post your state of tune and remap type. If you are stage 3, then you should be maxing out the MAF reading on vag-com = 464.08
Vag-com > engine module > measuring blocks > block 003 > Log > Start.
Use 3rd gear 3500 - 7000 rpm.
Save file and post results here.
HTH
https://www.speedcams.co.uk
B5 2.7t S4 - gone
B5 2.7t RS4 - gone
Ed 30 Golf DSG - gone
2018 Golf R 7.5
maxrs4
Post by maxrs4 » Mon May 18, 2009 9:11 pm
what is this vag-com? i have been using a techie snap on tool that logs about a million things as u drive lol!
Nige_RS4
Post by Nige_RS4 » Mon May 18, 2009 9:17 pm
maxrs4 wrote:what is this vag-com? i have been using a techie snap on tool that logs about a million things as u drive lol!
The snap on tool is good, but not as good as vag-com!
Do a search on google for it - lots of info.
B5 2.7t S4 - gone
B5 2.7t RS4 - gone
2018 Golf R 7.5
rtd
Post by rtd » Mon May 18, 2009 9:23 pm
Nige my car is standard at the moment
Volvo XC90
C7 - RS6
C6 - RS6
B5 - RS4
Nige_RS4
Post by Nige_RS4 » Mon May 18, 2009 9:30 pm
rtd wrote:Nige my car is standard at the moment
A std RS4 will see between 280 and 300 g/s on the MAF IIRC.
B5 2.7t S4 - gone
B5 2.7t RS4 - gone
2018 Golf R 7.5
Jules
Post by Jules » Mon May 18, 2009 10:23 pm
Apperently i maxed the new maff fitted saturday,Grizz said.
Didn't know what the hell he was on about,but it sounded good :lol:
Sql_RS4
Post by Sql_RS4 » Mon May 18, 2009 10:24 pm
I have just changed my MAF - was also down on power.
Old one peaked at 270 g/s
Brand new from Audi showed 320 g/s today but I feel the car is still slower than it used to be and cannot find out why.
We checked boost with my friend today and it acts weird - car wants 2.4, boost is much lower, then it goes up to 2.3 when it is 2.3 expected by car, keeps it and then looses a lot and goes down to like 2.0
I no longer have that kick in the @ss that used to be there at around 3750-4000 rpms - it is more smooth and linear now.
Any ideas? My mechanic said it might have something to do with clogged cats? Or is that a poor guess?
neckarsulm
Post by neckarsulm » Mon May 18, 2009 10:34 pm
Have you pressure tested yet as that sounds like a boost leak?
Sql_RS4
Post by Sql_RS4 » Mon May 18, 2009 11:36 pm
Will try to do so asap.
Was just reading some older posts and started to think if N75 can cause some of this - I have already changed both DVs and MAF so that's the last thing to check I guess?
Jules
Post by Jules » Tue May 19, 2009 8:35 am
Yeah,when we changed my maff we did the n75 at the same time just in case,there not expensive so got to be worth a try :wink:
Users browsing this forum: No registered users and 88 guests
