RS4 Pads and Discs so soon?
Bump.
Audi are quoting me £191.63 + VAT for the fronts (8E0698151Q) and £137.05 + VAT for the rears (8E0698451P)
Maybe the Q is the revised part?
Conversely, GSF will do pads for £100.63 and £48.88 respectively.
58 C6 RS6 Stage 2+
58 C6 A6 Allroad 2.7 TDi
Previous:
2000 B5 S4 MRC 550 Saloon
2007 B7 RS4 Saloon
1994 S2 Coupe
Previous:
2007 B7 RS4 Saloon
1994 S2 Coupe
So, are the revised pads from Audi IMPROVED to avoid the grooving issue???
I am using EBC YellowStuff. So far so good. I'd say as good as originals and at GBP 166 inc. VAT a god option. They come with shims and pad wear indicators, but currently require slight modification to fit. Correct ones are in the pipeline apparently.
Replaced pads a few weeks ago. Managed to catch them just as they had worn down to the pins but before they damaged the discs. Some pics below to show how much of the pad is left when the pins are exposed.
Will try and get some measurements of the thickness left but the battery in my digital caliper was dead.
Mine had same amount of wear when I changed them - probably half the pad was left.
If you search on here, seems the drilled holes in the discs blocking up with crud may be leading to disc judder. I'm not sure but did unblock all the holes and will do if the clog up again (a boring process aided by a few cans of Stella)
In my case the pads had done about 27K from new
I do about 20K a year but most of it is racked up on a 25 mile each way commute to workwhich is split about 50/50 between good A-road and dual carriageway. Traffic density means the brakes usually don't get a hard time.
Not convinced that blocked holes can lead to brake judder. However the holes can take some cleaning out if left a while. I've done mine a few times now and have twisted off a drill bit when doing it.
Recently my brake servicing light came on and I visited my local Audi dealer to get it checked.
I have done 15,000 miles in the last year (Owned the car for 1 year) and was sold the car with the statement that new front discs and pads were fitted.
Interestingly the dealer has stated that the disc is 'Lipped' and that this is causing the brake service light to come on..... Although at the next service in 3000 miles they have recommended replacement of discs and pads. Would this be correct or usual? The car is still under warranty until August 17th 2009.
Does anyone know the minimum recommended disc width?
Interestingly my quote was £1085.00 for front discs and pads!
Users browsing this forum: No registered users and 181 guests
