What would i expect to get if?
2.7 V6 30v biturbo - 380 bhp
drjones1
Post by drjones1 » Sat May 09, 2009 8:41 pm
Hi lads,
What hp & torque would i get if i gutted precats fitted a Milltek cat back, front mounted inter cooler and stage 2 re map from MRC? to an otherwise standard B5 RS4..?
Thanks in advance.
Darren.
A8 3.0TDI quattro sport (every day)
B5 RS4 (the second one)
UR quattro (450bhp)
AC Cobra (replica)
Ford GT40 (replica)
A3 (Wife)
Sit on lawn mower (12hp....)
rickoshea
RE: What would i expect to get if?
Post by rickoshea » Sat May 09, 2009 11:48 pm
Why not ask MRC ? I'd have guessed around 460 - 470 bhp but I'm no expert.
Rick.
jimbo1234567
Post by jimbo1234567 » Sun May 10, 2009 10:22 am
480
rhunter203
Post by rhunter203 » Sun May 10, 2009 4:12 pm
I recently asked Lucas that question. I was told 480-500 although 500 would be pushing the turbos to their limit!
MRC 490BHP 500ft/lbs RS4
3.6 0-60 12.04 1/4M
Ads4
Post by Ads4 » Sun May 10, 2009 8:01 pm
Gutted pre-cats, Milltek and remap should see 440 - 450bhp. Add another 30bhp for FMIC and loads more torque :thumb:
Adam.
MRC B5 S4 Avant.
drjones1
Post by drjones1 » Sun May 10, 2009 8:33 pm
Thanks for the replys.
Sorry for all the questions but in line fives are my speciality..
How about if i stuck with the standard intercoolers and added .5 water injection jets to the exit of both intercoolers. Air speed in theory should stay up with standard intercoolers and water has a dramatic effect on cooling if applied correctly + you can add a bit of alcohol...
I have carried out lots of tests on air speed vs lag i.e small intercoolers vs big and the best i have found is two small in line as attached. this also has water injection in both intercoolers. It runs 2.3 bar of boost and you only see 15 degrees rise in temperature from cruising to full boost with virtually no lag..
UR quattro (450bhp)
AC Cobra (replica)
Ford GT40 (replica)
A3 (Wife)
lengster1
Post by lengster1 » Sun May 10, 2009 9:05 pm
Now that looks like a bit of seriously modified kit !!!!!
drjones1
Post by drjones1 » Sun May 10, 2009 9:29 pm
Tis.. to much really.. 0-100 in just over 8 if you have the nuts to keep your foot in.. no electronic help with this old girl.. Managed to do a set of tyres in 700 miles, try getting 215 50 15s..
The whole aim was to keep it looking standard, which it does when its in one piece...
UR quattro (450bhp)
AC Cobra (replica)
Ford GT40 (replica)
A3 (Wife)
lengster1
Post by lengster1 » Sun May 10, 2009 9:49 pm
Woohoo now thats going some!!!!!!! It looks like a no expense spared top quality job,well done that man,look forward to what you do to your b5
roi354
Re: RE: What would i expect to get if?
Post by roi354 » Mon May 11, 2009 8:09 pm
drjones1 wrote:Thanks for the replys.
Think you've pretty much decided on the route to go down there!! As you've used water inj before then you know the benefits especially with regards to methanol. As long as its mappable you'll probably be fine - but you must know that from your other car ;)
rickoshea
RE: Re: RE: What would i expect to get if?
Post by rickoshea » Mon May 11, 2009 8:31 pm
Qu. Where does one get hold of Methanol in sufficient quantities for a car ?!
roi354
Post by roi354 » Mon May 11, 2009 9:04 pm
http://www.mistralni.co.uk/details.php? ... 7QodDQutbw
http://www.lindchem.co.uk/
for e.g. :wink:
Don't get it on your hands though, seeps through into your bloodstream :shock:
jimbo1234567
Post by jimbo1234567 » Mon May 11, 2009 10:54 pm
water/meth is fantastic at making iat,s good. better than a fmic and probably easier.
drjones1
Re: RE: Re: RE: What would i expect to get if?
Post by drjones1 » Mon May 11, 2009 11:03 pm
jimbo1234567 wrote:water/meth is fantastic at making iat,s good. better than a fmic and probably easier.
It certainly does work and it gives you that comfort of a bit of top end protection against detonation..
Mind you you have to remember to switch it off before the rev limiter (neat methanol) it can make a bit of a mess when it backfires with the throttle shut..
I will have to give it ago, water that is, and do some Vag Com logging to see the effects on inlet temperatures..
UR quattro (450bhp)
AC Cobra (replica)
Ford GT40 (replica)
A3 (Wife)
quattronutter
Post by quattronutter » Mon May 11, 2009 11:04 pm
fmic and w/i keep air temps down nicely,especially during high gear pulls at full load
