16985 - Internal Control Module: Memory Check Sum Error
Diagnostic Trouble Codes (DTC) / VCDS (VAG-COM) forum
ecain63
Post by ecain63 » Sat May 02, 2009 6:28 pm
Anyone know what this one is? Only popped up today.
P0601 - 008 - Implausible Signal
Now Sold!
'03 Daytona Grey RS6 Avant.
275 Vreds.
MRC custom map with TCU.
Miltek Resonated.
Hi Flow filters.
19" 'Plus' (Grey) rims.
PetrolDave
RE: 16985 - Internal Control Module: Memory Check Sum Error
Post by PetrolDave » Sat May 02, 2009 6:44 pm
ecain63
Post by ecain63 » Sat May 02, 2009 6:51 pm
Thanks mate. I'll reflash by disconnecting the battery and see what happens.
Now Sold!
275 Vreds.
Miltek Resonated.
Hi Flow filters.
ecain63
Post by ecain63 » Sat May 02, 2009 8:08 pm
Sorted. Disconnected the batt and cleared all dtc's. seems to have cured the issue even after a drive. If it comes back then i'll post up again.
Eddie
Now Sold!
275 Vreds.
Miltek Resonated.
Hi Flow filters.
ecain63
Post by ecain63 » Mon May 04, 2009 9:04 am
Well, a good bit of driving done since the reset and so far so good. No more fault codes. Must have been an oddity!
Now Sold!
275 Vreds.
Miltek Resonated.
Hi Flow filters.
grizz
Post by grizz » Mon May 04, 2009 9:23 pm
Last time i had a car in with this it was down to a "iffy" remap . Removed the "iffy" remap and replaced it with a custom-code phase 1 map & all was fine .
Unit 20
0151 3366888
ecain63
Post by ecain63 » Tue May 05, 2009 5:35 pm
If it pops up again mate i'll give you a buzz. Ive seen that its mainly an issue with the APR maps. how much for the CC phase 1?
Now Sold!
275 Vreds.
Miltek Resonated.
Hi Flow filters.
S2tuner
Trader (Expired)
Post by S2tuner » Wed May 06, 2009 10:21 am
If the code goes away, there's nothing to worry about, it's not down to an "iffy" remap, and MTM are definitely not people who do "iffy" remaps.
ecain63
Post by ecain63 » Wed May 06, 2009 2:42 pm
Fair point well presented.
Now Sold!
275 Vreds.
Miltek Resonated.
Hi Flow filters.
vinny
Post by vinny » Sun May 10, 2009 2:57 pm
hey eddie, that "check sum error" is the ecu telling you its in need of an upgrade - preferably factory. go by the dealer and see whats involved. dont know how you guys work there, but in SA (im at the dealer) we flash the ecu with an overwrite from the factory
S2tuner
Trader (Expired)
Post by S2tuner » Sun May 10, 2009 3:34 pm
Your suggestion is correct for the newer TFSI ECU's, but NOT for an RS6 vinny, sorry to correct you.
ecain63
Post by ecain63 » Sun May 10, 2009 6:21 pm
Mine has updated software anyway. But as S2 said, its not an RS6 issue.
Now Sold!
275 Vreds.
Miltek Resonated.
Hi Flow filters.
ecain63
Post by ecain63 » Mon May 18, 2009 8:02 pm
Still no return of the DTC so im guessing that its all cured. Worth a try if you are ever confronted with the code.
Now Sold!
275 Vreds.
Miltek Resonated.
Hi Flow filters.
Post by Shoppinit » Fri Jun 05, 2009 12:13 pm
How's it working now? Still no problems?
ecain63
Post by ecain63 » Fri Jun 05, 2009 4:39 pm
Still no return of the error. reckon the ecu had tripped out. How's yours?
Now Sold!
275 Vreds.
Miltek Resonated.
Hi Flow filters.
Return to “DTC / VCDS”
