amenwankeldude wrote:60ft and trap speeds are the best metrics and NEVER lie.
with awd the 60' can be skewed a bit, imho
the RS4 is very heavy, cars in the States weigh ~4000 lb
I've not to the cab, I've driven the cab for months and yes the weight is definitely a factor. All I'm saying is that I reckon the B7 is down on power and something isn't right. Jim's car now feels bang on.W8PMC wrote:I totally disagree, my car feels full of it's claimed 420+BHP. Your car may be a bit or alot slower than mine, infact yours is a cab so it will be slower as it's around 200KG heavier than mine.Contigo wrote:I honestly don't thik that the stock B7 performs like a 414bhp car though in the real world. I've owned a B7 and driven a Cab for months and it felt down on horses. The stock B5 at 380 felt right and my remapped B5 will embarrass a stock B7.
I ain't in here to troll,. 'm relating to whaty W8PMC said that it's all about how they drive in the real world and for me it's a bit of a let down. The fact that these cars don't make the quoted manufacturers claimed BHP output does not surprise me in the sligtest.
I've been in Jims car and that now feels how mine should have been from Audi so something is amiss.
Without raising the Cab/Avant/Saloon debate, the saloon is the lightest of the 3 bodies by a fair margin, with the Avant next & Cab the heaviest. They all have the same Audi claimed power output of 414, so it's safe to assume with the same driver/conditions that the Saloon will feel closer to it's output, followed by the Avant & then the Cab.
Power & wieght will always be the biggest contributors.
Look at the stats. An E60 M5 claims the same 0-60 time as the B7 RS4 saloon, however it's 100BHP more powerful, but weighs around 300KG more. The C5 RS6 posts the same 0-60 time as the B7 RS4, but is 170BHP more powerful, however a phat 1/2ton heavier.
great post & logic...rjkflyer wrote:So, here's a view. What max speeds have you seen an unrestricted B7 RS4 do, under cool conditions????
Maximum drag-limited top speed is about the best indication of a car's power to the wheels.
At drag-limited speed ( zero acceleration), we can calculate that Vmax = 53 * cube root (Power at wheels / Cd.a) where Power = SAE hp, and Cd.A in foot sq.
So, for a RS4, where power at wheels should be ca. 80% of engine output = 414 * 0.8 = 331 hp, and Cd.A = 0.34 * 22 = 7.48 ft sq.
Vmax = 53 * cube root (331/7.48) = 187 mph
Now correct for rolling resistance, which is ca. 3% for tyres on asphalt, so Vmax = 181mph.
As another example, the 3.2 A4Q will JUST about get to the limiter (155mph). Trust me.
Let's see: Vmax = 0.97 * 53 * cube root (0.8 * 265)/(7.5) = 156mph. Correct.
All at 65 deg F and 990 mb (oddly SAE hp seems to be at that pressure).
Just ran some vagcom logs on my car....SR71 wrote:I think we're talking at cross-purposes here...
We can all make up our own minds about whether the cars produce the Audi quoted figures, but the real question is why the variance?
We have a 20% spread on cars with no VAGCOM faults thrown up.
Now if someone can confirm that the difference between running 275/30's at 25psi and 255/35's at 50psi is 40hp, then we know the answer.
Conversely, if someone can confirm that the TC was switched off on all cars prior to running, we know that there is a good chance the EDL isn't screwing with things.
Similarly, if the power flap which comes online @ >5000 rpm is f**ked on some cars (MacRS4 & Klauster?), then effectively isn't the mass flow rate choked and power will be down?
I have to say I find the RS4 study guide ambiguous because to my mind the RS4 does not have a variable intake manifold, yet the text makes reference to a "intake manifold changeover valve"...
I'm not sure of euro wts, but every US test had the curb wt close to 4000, Audi specs it at 3957...not sure of fuel load...SR71 wrote:caldy,
But those vanes are there to introduce "swirl/tumble" for the purposes of operating in stratified mode correct?
Like here: http://sankaranv.blogspot.com/2009/01/f ... ction.html
I can't understand how the action of these vanes "shortens" the intake path?
They're not responsible for acoustic tuning of the manifold from a performance point of view are they?
Gazzer,
How do you get 4221lbs?!
The saloon weighs 1650kg, so with me onboard, I'd be looking at ~1750kg or ~3900lbs...
Yep sorry got that wrong...SR71 wrote:caldy,
Gazzer,
PS: I know you can't switch off the EDL (or for that matter the ESP - the system as I understand it will re-activate if limits are exceeded regardless of switch position), but it stands to reason that for comparison purposes all the cars should have been run with either TC on or off. How that actually affects the ABS, TC, EBD & EDL is anyones guess...
Users browsing this forum: Google Adsense [Bot] and 272 guests
