RNS-E issue
RNS-E issue
Ive got a little issue with the RNS-E in my RS6, it don`t seem to see satelites all the time, some times you can be in the the for 30 mins and it still says i`m still at home. I i had the unit replace under warranty 8 months ago so i don`t think its the unit, so my thoughts are it the GPS antenna. Are the ones that you fit in the dash easy to fit?
tartan_rob
RE: RNS-E issue
Is the car under warranty etc? What type /age of car etc..?
2017 Kawasaki Z1000
2014 RS6
2014 S1
2014 RS6
2014 S1
RE: RNS-E issue
Audi warranty ran out last month and warranty direct can`t sell me a warranty yet, anyway its a 2003 saloon RS6.
- PetrolDave
Re: RNS-E issue
Drop the glovebox, stick the antenna on the under surface of the dash (sensitive side up!) and plug the antenna lead into the RNS-E.johnny11 wrote:Are the ones that you fit in the dash easy to fit?
If it takes you more than 30 minutes you're on a go slow
RE: Re: RNS-E issue
so all i need are the RNS-E removal keys and one of these then?
http://cgi.ebay.co.uk/GPS-ANTENNA-FAKRA ... 240%3A1318
RE: Re: RNS-E issue
also can someone tell me if these keys are the correct ones for removing the RNS-E
- Virdee Autos
- Trader (Expired)
RE: Re: RNS-E issue
Yep they look good enough to me!
They will only fit one way though.
Some keys are usually labelled (TOPL/R)
Virdee Autos ~ 07950-526592
RE: Re: RNS-E issue
all done, and yea very easy to do, located new gps antenna under dash, took out RNS-E plugged in new atenna, then neally straight away it saw 7 satalites, which proved the roof antenna was faulty.
thanks all for help
thanks all for help
Users browsing this forum: No registered users and 31 guests
