corroded oil pipe major leak on the m62!!!
HI can anyone help please need a part number for the oil cooler pipe it runs from the oil cooler raditor to the oil filter housing its a flexy rubber pipe at each end and metal piece of pipe in the middle
thanks
where will i be able to find a new or used oil cooler rad????
thanks
RE: corroded oil pipe major leak on the m62!!!
This is a common problem on the B5 RS4! I replaced mine last year when it started weeping oil.
You shouldn't need a new oil cooler, just a new return pipe - they are around £110 each.
Everyone go and check yours tonight!
https://www.speedcams.co.uk
B5 2.7t S4 - gone
B5 2.7t RS4 - gone
Ed 30 Golf DSG - gone
2018 Golf R 7.5
B5 2.7t S4 - gone
B5 2.7t RS4 - gone
2018 Golf R 7.5
Thanks just ordered one from TPS in leeds
B5 S4 KO'4 black saloon sunroof......
B5 RS4 Goodwood Green,sunroof, nav tv, short shifter,
B5 S4 Nogaro saloon
B5 S4 Black saloon,
B5 RS4 Misano red,
B5 RS4 noggy blue,
B7 RS4 Sprint Blue.
B5 RS4 avus silver
B5 S4 Nogaro saloon
B5 S4 Black saloon,
B5 RS4 Misano red,
B5 RS4 noggy blue,
B7 RS4 Sprint Blue.
B5 RS4 avus silver
- Virdee Autos
- Trader (Expired)
Yep one of the first things I did to mine when I bought it. Was corroded on the oil cooler side, which is common.
Virdee Autos ~ 07950-526592
sorted by autec in dewsbury good job done and cleaned the car from underneath .
B5 S4 Nogaro saloon
B5 S4 Black saloon,
B5 RS4 Misano red,
B5 RS4 noggy blue,
B7 RS4 Sprint Blue.
B5 RS4 avus silver
B5 S4 Nogaro saloon
B5 S4 Black saloon,
B5 RS4 Misano red,
B5 RS4 noggy blue,
B7 RS4 Sprint Blue.
B5 RS4 avus silver
mine was found to be showing some very small signs of corrosion so have replaced both pipes..........
Volvo XC90
C7 - RS6
C6 - RS6
B5 - RS4
C7 - RS6
C6 - RS6
B5 - RS4
Not another common fault....Where will it end??lol. So is this easy to check for or do I have to take the engine n box out???lol
- quattrokid1
- Top Gear
anyone got any photos of what to look for please?
just passed its MOT today so assume its ok!!
Misano red B5 RS4 710 D/V's SERVICED BY EL GRIZZMO:).... Wife's !!
Tornado red WR quattro
UrS4 saloon auto:) resurected by Unit20
Audi S3 8L Imola yellow
Audi B6 S4 Cabrio SOLD
Audi 100 2.2E SOLD
Audi 80 cabrio 2.6 V6 (SOLD)
Audi 90 quattro SOLD
Audi 100 2.2E SOLD
- Virdee Autos
- Trader (Expired)
quattrokid.....MOT wouldn't really be an issue for this pipe.
And also you'd only see this once the engine undertray has been removed.
No engine or gearbox to take out! Just remove the undertray, and check the pipe on the RHS of the oil cooler for any corrosion. Infact all the pipes to the oil cooler, both cooler side, and oil filter housing side.
- leyshonbrent
Part No as follow if anyone's interested:
W8DO317815L SUPPLY
W8DO317815M RETURN
Easier to take off front bumper gives full access to couplings - can be tricky to remove due to galvanic corrosion between alloy oil cooler connection and steel coupling takes few hours - I then greased the connctions on replacement. They corrode from crimp coupling connection on pipe back to coupling bolt due to being exposed to road salt etc - definately worth checking yours from underneath.
W8DO317815L SUPPLY
W8DO317815M RETURN
Misano Red B5 RS4 - For Best
Battered A4 1.9 TDI Avant - my weekend van and Station Wagon
Mk1 Escort Mexico - Childhood Sweetheart
For Family - VW Touran 2.0 TDi Sport
- quattrokid1
- Top Gear
Re: RE: corroded oil pipe major leak on the m62!!!
ok, I'll get it looked at, thanks VirdeeVirdee Autos wrote:quattrokid.....MOT wouldn't really be an issue for this pipe.
Audi 100 2.2E SOLD
Audi 100 2.2E SOLD
Users browsing this forum: No registered users and 99 guests
