9 Spoke Wheels
9 Spoke Wheels
I'm looking at buying a set of A8 19" alloys with adaptors to fit a Bora...what spacers will I need?
Re: rs4 wheels
To fit a Bora?........ who cares? [img]images/graemlins/roundeyes.gif[/img]
Andiroo
Andiroo
Previous :RS4 B5 (Noggy Babe), 934 GT2, 996 Cup.
WIP :to be advised.....
RS246 Live! CLICK HERE for details of the big RS246 event for 2008 **And how it died on it's arse**
Re: rs4 wheels
Bora runs the smaller PCD than the Audi, IIRC 100mm as opposed to 112mm. If I'm right, then you will need one of
a) Adapters
b) Redrill your hubs
If you are talking about wheels with low offset (ie, 25mm) you will probably be in luck as the chances are you would need 15-25mm spacers in orders to clear get the ET somewhere back in the correct region. That will be ideal as typically that is the size of bolt on adapters.
I am guessing the Bora arches are going to be similarly spacious to the Golf arches, in which case there is loads of room so assuming the correct offset is obtained and that you aren't talking about 10" wheels you will probably be in luck. I ran 245/18s on my Golf and there was plenty of room for bigger/wider
a) Adapters
Re: rs4 wheels
The Bora is a PCD 5x100. The wheels are PCD 5x112. I used adaptors to get them to convert and fit my bora! No arch mods were required!
There a 8.5x19" wheel with a offset of 45
Hope that can help Jon!
Re: rs4 wheels
Yummy!!
Users browsing this forum: No registered users and 13 guests
