New cylinder block - 2 weeks left on warranty!!!
jimbosale
Post by jimbosale » Thu Apr 09, 2009 9:21 am
Took the RS4 into the garage as I had a engine warning light come on. Diagnostics confirmed it was a failed solenoid for the secondary air. Took the car into Worthing Audi and had a phone call asking whether the car was using a lot of oil!!! When ask why, I was advised that while changing the solenoid they had found a lot of burnt oil under the car. Further diagnostics found that the engine was 'fluttering' at 1700rpm a known sign that the there may be a problem with the cylinders. Cylinder head was removed and 3 of the bores had started to score and polish. 3 weeks later and I have a new cyclinder block and remapped engine. Apparantly to avoid this problem the engine has to run 2-3 degrees hotter. All work done under warranty with only 2 weeks left!!!!!! Car had done 38,000 miles. All credit to Worthing Audi, the car had only gone in for a cheap solenoid replacement and ended up as a £9k job!!! If this hadn't been picked up I could have had a nasty bill in 6 months time.
PetrolDave
Re: New cylinder block - 2 weeks left on warranty!!!
Post by PetrolDave » Thu Apr 09, 2009 1:21 pm
jimbosale wrote:Apparantly to avoid this problem the engine has to run 2-3 degrees hotter.
Hmmm.... not sure I see how that would make a difference?
Did they give you any proof of this statement?
Not seen anyone else post this issue either on forums here or in the US.
SR71
Post by SR71 » Thu Apr 09, 2009 2:02 pm
jimbo,
Can you expand on the symptoms of a "fluttering" engine?
Are you talking about a "fluttering" mass flow rate?
58 C6 RS6 Stage 2+
58 C6 A6 Allroad 2.7 TDi
Previous:
2000 B5 S4 MRC 550 Saloon
2007 B7 RS4 Saloon
1994 S2 Coupe
jimbosale
Post by jimbosale » Thu Apr 09, 2009 2:09 pm
I am not too sure. It is something to do with the bores being silicon carbide lined and I believe is not uncommon. It only happens to cars in the UK and is not has not been a problem in Germany. I guess something to be aware of.
mac4RS
Post by mac4RS » Thu Apr 09, 2009 2:20 pm
Jimbo, I'm currently having probs with my motor...thro' many discussions with my dealer, it was mentioned that I'm running ECU version 0080. He stated that version 0090 was for motors that needed to run at higher temperatures due to lots of town driving etc...? (still unsure what he really meant)
Is your remapp using version 0090.
silverRS4
Post by silverRS4 » Thu Apr 09, 2009 2:34 pm
SR71 wrote: Can you expand on the symptoms of a "fluttering" engine?
I'm sure the flutter Audi is referring to is piston ring flutter. It usually happens at high RPMs under low engine loads. In these situations, there isn't enough cylinder pressure to keep the rings square to the bore. This results in more blow-by and higher crankcase pressure. This phenomena shouldn't have any affect on the mass-air sensor readings. I believe high RPM flutter is normal. If the ring flutter happens at lower RPMs, bore wear will be accelerated - which is apparently what happened to jimbo's engine. Why exactly? Hard to say...
jimbosale
Post by jimbosale » Thu Apr 09, 2009 2:45 pm
I am not sure what ECU version software they remapped to. Is there are an easy way to tell? It sounds like the same thing though - lots of stop start driving which apparently is causing the problem (mind you I do 60 miles a day and this isnt town driving - mostly country roads).
WBRS4
Post by WBRS4 » Thu Apr 09, 2009 5:07 pm
jeez! where do these problems keep coming from??
hope everything works out fine for you
jimbosale
Post by jimbosale » Fri Apr 10, 2009 3:42 pm
Bearing in mind the amount of work I have had done on this car - engine has bascially been rebuilt and numerous components changed do you think I should extend the warranty?
rsowneraudi
Post by rsowneraudi » Wed Apr 15, 2009 12:12 pm
the 'flutter' refered to is probably when you hold the revs steady at between 1,500 and 1,800 revs, you will find that it will not feel smooth i.e a flutter
SR71
Post by SR71 » Wed Apr 15, 2009 1:13 pm
What are we talking about here?
* The engine refusing to maintain constant revs between these limits?
* The actual car vibrating/fluttering at these revs as result of the issue?
Thanks.
58 C6 RS6 Stage 2+
Previous:
2007 B7 RS4 Saloon
1994 S2 Coupe
jimbosale
Post by jimbosale » Wed Apr 15, 2009 2:36 pm
i believe that due to the problem with the cylinders the engine was 'fluttering' at the rev range. Had the latest ecu software flashed and the engine is running well. RPM is around 1600 on cold start. Apparantly this helps avoid future problems by warming the engine quickly.
rsowneraudi
Post by rsowneraudi » Wed Apr 15, 2009 3:27 pm
the engine will hold a steady rpm but you will feel a 'vibration' through the vehicle and you will hear the slightly different engine note
Users browsing this forum: Google [Bot] and 317 guests
