Weird HVAC DTC
Diagnostic Trouble Codes (DTC) / VCDS (VAG-COM) forum
Weird HVAC DTC
Post by Shoppinit » Mon Apr 06, 2009 4:22 pm
I just scanned my car and was surprised to see this:
Address 08: Auto HVAC Labels: Redir Fail!
Part No: 4B0 820 043 AM
Component: A6-Klimavollautomat 0105
Coding: 00000
Shop #: WSC 00000
1 Fault Found:
01592 - Air Quality Sensor (G238)
57-00 - Electric Circuit Failure
When I went back to the module to clear the DTC, I got a time-out error. In fact I had to try and connect several times before it would finally connect. The DTC won't clear.
Looking back on previous logs from autoscans, the HVAC is completely missing. I'm guessing that the vagcom tried to connect to it, couldn't and assumed the car didn't have one.
2 questions:
1. What an earth is an "Air Quality Sensor"
2. Should I be concerned about this module playing up considering that I can't find anything that doesn't work as it should...
PetrolDave
RE: Weird HVAC DTC
Post by PetrolDave » Mon Apr 06, 2009 4:35 pm
Do you have the automatic re-circulate option?
That uses an "air quality sensor" to decide when there are fumes in the incoming air and switch to re-circulate mode.
RE: Weird HVAC DTC
Post by Shoppinit » Mon Apr 06, 2009 4:37 pm
I believe I do, but I couldn't say for sure. Surely an RS6 would have that as standard? It's not so much the air quality sensor that worries me as the difficulties in connecting to the HVAC with the vagcom.
RE: Weird HVAC DTC
Post by Shoppinit » Mon Apr 06, 2009 10:54 pm
I'm guessing that the automatic recirculate is the recirculate button with the little A in it. In which case, yes I do have it.
Is it worth replacing the Air Quality Sensor?
PetrolDave
RE: Weird HVAC DTC
Post by PetrolDave » Tue Apr 07, 2009 1:16 pm
What version of VAG-COM are you using, and what lead do you have? If you have a serial lead are you using a USB to serial converter?
USB to serial converters are not supported because of problems with unreliable connections.
I know that some modules (e.g. the phone module) can be very "fussy" - that module was really difficult to reliably connect to prior to the 6xx version of VAG-COM.
Air Quality Sensor? - I have the auto re-circ (an option) on my RS4 and find it works well when I'm behind a petrol car but it's unable to detect the emissions from a diesel car/lorry/bus. Is it worth replacing the sensor? - do you find yourself having to hit the manual re-circ button often?
RE: Weird HVAC DTC
Post by Shoppinit » Tue Apr 07, 2009 1:24 pm
I'm using the latest version of VCDS (805) with a genuine Ross Tech HEX-USB+CAN cable. I wonder if the faulty G238 could be causing the communication unreliability with VCDS.
Until you asked me, I didn't even know that automatic recirulation existed! So I won't miss it. I'm just anal about having everything working on my car :) That and seeing if it improves communication with the HVAC...
It looks like quite a cheap part. Do you know if it's reasonably accessible?
PetrolDave
Re: RE: Weird HVAC DTC
Post by PetrolDave » Tue Apr 07, 2009 1:26 pm
Shoppinit wrote:Do you know if it's reasonably accessible?
Sorry I don't know, anyone got access to ELSA or the Bentley manuals?
jamesthecat
Location: Finding out were people live,.Ask dvla its easy if you own private land.
Re: Weird HVAC DTC
Post by jamesthecat » Fri Mar 23, 2012 10:00 pm
Shop did you ever sort this out?,mine has just come up with same error,any idea whats involved in changing it or cost
cars,mk1 1.3 escort,mk 3 1.6 cortina,mk 1 granada 3.0s,1.7 morris marina,hillman imp,mini with worsley engine,
mk 4 2.0 cortina,mk 1 xr2, mk2 xr2, 2.0glsi sierra,mk 3 jag,subrau turbo x3,golf mk 1 gti,skoda octavia elagance,
evo 6,evo 8,rover 1.4tc,golf gttdi,toyota surf 2.4,toyota surf 3.0 skoda superb elagance x2,
rs6 x4.land cruiser amazon 4.2td, mr2.
Bikes,FS1E,honda cb 650,yam thunder cat,r6,gix 600 x 3 gix 1000 x2 kwak zx12 x2
Re: Weird HVAC DTC
Post by Shoppinit » Fri Mar 23, 2012 10:16 pm
Wow, blast from the past. :)
Yeah, I changed the air quality sensor and the DTC went away. I think. The Vagcom doesn't like going into the HVAC - I think it's scared.
It's a really easy fix. Takes about 3 minutes. I think it cost about £20 but I could be imagining that.
jamesthecat
Re: Weird HVAC DTC
Post by jamesthecat » Sat Mar 24, 2012 1:00 pm
Cheers , will get my hammer out and sort it.
Re: Weird HVAC DTC
Post by Shoppinit » Sat Mar 24, 2012 1:15 pm
It's just attached to the pollen filter. It hangs off the edge of the filter holder, IIRC. You should be able to identify it pretty easily if you get a new part. Let me know if you need any more info.
Return to “DTC / VCDS”
