LED DRLs - latest improvements
P_G
Post by P_G » Fri Apr 03, 2009 9:57 am
I haven't either but by the looks of things we'll have two people there who have fitted them in Jim and Andy?
Will order parts next week.
klauster
Post by klauster » Fri Apr 03, 2009 10:36 am
if you can order we the bits too, ill settle up with on the day :beerchug:
Marcus-RS4
Post by Marcus-RS4 » Fri Apr 03, 2009 11:56 am
Problem is, how are you going to plug in the soldering iron at the RR day? Its best to do it properly rather than with scotch locks?
klauster
Post by klauster » Fri Apr 03, 2009 12:08 pm
ah :(
bn8959
Post by bn8959 » Fri Apr 03, 2009 1:50 pm
I can bring gas soldering iron :)
2016 C7 RS6 - Panther Black
Previous:
2008 B7 RS4 Avant, Phantom Black
Marcus-RS4
Post by Marcus-RS4 » Fri Apr 03, 2009 3:45 pm
Sold! :)
seventeenAPG
Post by seventeenAPG » Mon Sep 27, 2010 12:30 pm
rs4v8 wrote:Have to say I'm delighted with the way it looks now. Big improvement. Even the missus noticed the difference and believe me that is saying something! :D
The credit goes to the guinea pigs who went first though! rjkflyer in particular. Cheers :beerchug: :notworthy: Your resistor values do indeed work with regards fooling the lamp failure monitor and theres not too much heat at all. You can easily keep your finger on them so no danger of melting anything! Also glued the resistors to the covers.
Its the same type of bulb from the drls that goes in the rear cluster for indicators etc. Tried it very quickly as it was getting dark tonight. Looks pretty cool but not so easy to do the resistors. Gonna take the lining away from the boot tomorrow to see if there's enough space. Very difficult to show the effect properly but the LED binary on-off rather than dimming and lighting as per the filaments looks much better (just like my old m3!). LED lamp is in the cluster on the right shown below.
And, before anyone asks, yes it is the same car! just the front is nice and clean for the first pics!!
Just for reference, also a pic of the front in the twilight.
I know this is an old thread but was wondering if you got the rear indicators to work. I have just done the Drls and would love to change the flashers as well. I did try one of the drl leds (no resisitor) and the indicator just flashed really quickly like there wqs a bulb out. Might it be the case that a new under dash flasher unit is needed for both regular indicators and hazard warning system?
MB2
Re:
Post by MB2 » Wed Feb 08, 2012 5:14 pm
rjkflyer wrote:There is NO issue with heat from resistors if you size them correctly.
The mistake people make is assuming that the resistors need to take the full equivalent current of the existing 21W bulb (which in fact runs derated anyway). I conducted extensive experiments to see how high a value i could use which still kept the bulb failure detector happy.
I used 50W 24R for the DRL and 25W 68R for the sidelight bulb. It was testing them that showed they don't give off so much heat that it would be a problem, hence installing inside the headlight on the cap thus avoiding sealing and untidyness issues. The heat dissipation for the DRL resistor is hence ca. 8 watts, and for the sidelight ca. 3 watts (at worst case 14V). Not exactly high, and more importantly, in each case less than HALF the recommended dissipation for the resistor without any heatsink.
Also, remember that for the most part there is airflow albeit limited when you are moving.
The DRL LED bulbs are from http://www.v-leds.com , their 60M-SMT bulb.
Wiring not scotch locked - cos if ARSEY thinks LEDs are chav, then even worse is using SLs on a car like this - wires soldered to connectors on lamp holder, and colour matched.
Great post & saves me experimenting with resistor values etc. & also shows a neat way to manage wiring as have just got hold of some DRL LEDs will want to implement shortly so thanks. One question - could the large resistor not do double duty for both the DRLs & the side-lights as only one or the other will be on in use so is only to pass the autocheck on start up ?
DazN
Re: LED DRLs - latest improvements
Post by DazN » Thu Feb 09, 2012 3:07 pm
I used the same resistors in the caps and they generated a LOT of heat, I had to relocate them elsewhere with extended wires!
Audi S4 (B9)
Gone:
C63 Coupe (2014)
Audi S4 (B8)
BMW M3 (E90)
Audi RS4 (B7)
BMW M5 (E60)
BMW M3 (E46)
MB2
Post by MB2 » Thu Feb 09, 2012 9:00 pm
Thanks - did they melt anything or did you just feel uncomfortable with the heat build up ?
RIV
Post by RIV » Thu Feb 09, 2012 10:16 pm
I got led converters from eBay, no heat issues whatsoever, the original resistors get way too hot!!!
Users browsing this forum: Google [Bot] and 380 guests
