Idle speed
Laurie
Idle speed
Post by Laurie » Tue Mar 31, 2009 9:03 pm
Hi, I recently bought a 2003 RS saloon (64000 miles) which has just developed a fault of idling too quickly (up to 1500 rpm). It's recently been serviced with new plugs, filters and air mass sensors and the garage (a VAG independent) seems flummoxed by the error. The fault developed almost straight after they resealed the sump to cure a small oil leak. The only clue seems to be an error code related to a engine mounting vibration sensor, which shows up as a sporadic fault. Anyone come across this problem before? if so, would be great to hear what the solution is!
grizz
RE: Idle speed
Post by grizz » Tue Mar 31, 2009 9:32 pm
I would say the air box is not seated and you've got a air leak
Unit 20
0151 3366888
vinny
RE: Idle speed
Post by vinny » Wed Apr 01, 2009 8:30 pm
hey laurie, that fault with the engine mount is related to torque. dont think it will affect the idle though, but i know on the A8's, there is a factory mod where a blank off harness is sold to plug into the existing harness, to keep the ecu happy - i think these mountings are a little over-sensitive...
but like grizz says, maybe check that airbox for correct seating and vacuum/brake booster lines for leaks.....
Laurie
Re: RE: Idle speed
Post by Laurie » Thu Apr 02, 2009 10:30 am
vinny wrote:hey laurie, that fault with the engine mount is related to torque. dont think it will affect the idle though, but i know on the A8's, there is a factory mod where a blank off harness is sold to plug into the existing harness, to keep the ecu happy - i think these mountings are a little over-sensitive...
Thanks, Vinny and Grizz. both responses are really helpful. Bosche have told my garage that the rubber seals on the airflow meters can deteriorate and cause an air leak. My meters were recently replaced, but seals weren't in stock. They will be replaced next week. However, the problem started before the meters were replaced (that's why they were replaced), so I'll have to wait and see whether it does the trick.
Sounds like the engine mounting fault is a red herring, although my garage say that a faulty knock sensor can cause the engine idle speed to increase by foolling the ECU into thinking the engine is about to stall.
vinny
RE: Re: RE: Idle speed
Post by vinny » Fri Apr 03, 2009 3:50 pm
hey laurie, maybe the engine mount fault is a red herring... ive done yet another rs6 at the shop with high idling issues - replaced the following: seals where airmass goes into intake tubes, o-rings where airmass seals in airbox, ALL vacuum hoses - problem solved!!!!! :D car goes like a rocket!!!! dont replace just the seals on the intake tubes - do all as listed above
Users browsing this forum: Google [Bot] and 246 guests
