Can anyone help me out with suggesting what can be logged and checked with vagcom. Im new to the B7 so im not sure what there is to check its healthy or not.
Can airflow be done in the same way as on the B5, or a FATS run?
Going to get it on the laptop tonight and dont know what I need to look for or expect
What to log?
RE: What to log?
Absolutely.
Run a fault scan.
Same procedure.
Then, just scroll through the fields in <Engine>, <Measuring Blocks> and choose what you want to log.
My guess is, that if you're down on power, start with airflow and timing.
But before you worry, save yourself some effort and before you start logging, put some good juice in there, run it for long enough for the long-term adaptation to kick in...
My $0.02.
Run a fault scan.
Same procedure.
My $0.02.
58 C6 RS6 Stage 2+
58 C6 A6 Allroad 2.7 TDi
Previous:
2000 B5 S4 MRC 550 Saloon
2007 B7 RS4 Saloon
1994 S2 Coupe
Previous:
2007 B7 RS4 Saloon
1994 S2 Coupe
Re: RE: What to log?
SR71 wrote:Absolutely.
Run a fault scan.
Same procedure.
My $0.02.
Just out of interest, what is the "long term adaptation"
Gazzer
07/07 RS4 Avant Mugello Blue
RE: Re: RE: What to log?
Thanks for that I will have a go and report back with some numbers.
I run it on either v power, sainsburys super or ultimate all the time anyway!
006, 120 & 211 together give a good spread.
Users browsing this forum: Majestic-12 [Bot] and 133 guests
