Part number required for Y pipe seal
2.7 V6 30v biturbo - 380 bhp
N11LS_J
Post by N11LS_J » Wed Mar 25, 2009 1:26 pm
Gents
I have a boost leak from one of the inlets on the 'Y pipe', does anyone have the part number as Audi state you can't buy the seal, and need to replace the entire pipe???
Hoping someone can help, please see exactly which seal is required in picture below
thanks in advance
Nils
wjn
RE: Part number required for Y pipe seal
Post by wjn » Wed Mar 25, 2009 4:50 pm
078 133 148 D o-ring, costs about € 2,25 ex VAT. This is the one between the Y-intake duct and the pressure pipe.
wjn
Post by wjn » Wed Mar 25, 2009 4:52 pm
See also attachment:
andream88
Post by andream88 » Wed Mar 25, 2009 4:59 pm
Just solder them together.
The charge pressure pipes are tightened with only 1 bolt, they will always leak ;)
Andrea
Rs4 b5 06/2001
custom remap - KW V3 - Hotchkis Sways - ASP DTS with poly mount - 034 Street Mounts + Snub with bracket - Apikol rear diff mount and bushes - Gutted precats - DUH Fmic kit - 360x32 floating discs+brembo 6-pot at the front - 710Ns - OEM 18 Hard wheels - JHM shifter/linkage/spring etc - Podi.ca Boost Gauge - Powerflex Bushes - Afterrun mod -
N11LS_J
Post by N11LS_J » Wed Mar 25, 2009 8:12 pm
Thanks for that wjn
Andrea, shouldn't there be some flex in the joint hence the seal?
Instagram : n_i_l_s
andream88
Post by andream88 » Wed Mar 25, 2009 9:07 pm
nope.
those charge pipes are connected to the SMICS (Intercoolers) with silicon hoses.
cheers
Rs4 b5 06/2001
jimbo1234567
Post by jimbo1234567 » Thu Mar 26, 2009 12:22 am
nills .you will always get leaks from those joints . the only way to get rid of the leaks is for someone to weld them round= no more leaks.l the charge pipes are bolted to the cam covers and the link pipes to the intercoolers are flexis. if you go down this route you need to take both charge pipes off and remove the o rings then put it back together and get the charge pipes tacked to the ypipe in situ then take it off again and get them seam welded :biggrin2:
TopBear
Post by TopBear » Thu Mar 26, 2009 11:42 am
Mines is leaking as well, Grizz picked it up at the last service.
Who's had their's welded already, does it involve pull the front end forward to disconnect the alloy charge pipes?
:blackrs4: B5 RS4, MRC Remap, Milltek, RS6\B7 Brakes, Black\Carbon
rsmonkey918
Post by rsmonkey918 » Thu Mar 26, 2009 7:34 pm
Mine were given a hefty seeing to with silicone sealer when MRC detected a leak in the same place- sorted! Can see an alloy weld fracturing at some point.....
Steve
Steve
2000 X RS4 B5 Avus short shift, MTM/full Milltek to 460bhp, 19" Audi split rims/BBS CH's in anthracite, B7 front/rear big brake conversion, H&R ARB's/Bilstein PSS9's/ESP gearbox brace, retrofit RNS-E+Nav, ITG/MRC panel filter
2007 '07 Smart Brabus 101bhp, Bilsteins, Bentley Silverlake
2007 '56 Aprilia RSV Factory for some weekends
2004 '53 Honda Rune NRX1800 for other weekends
Virdee Autos
Trader (Expired)
Post by Virdee Autos » Thu Mar 26, 2009 8:28 pm
rsmonkey918 wrote:Mine were given a hefty seeing to with silicone sealer when MRC detected a leak in the same place- sorted! Can see an alloy weld fracturing at some point.....
Steve
Silicon - cheap and cheerful! Does the job!
Virdee Autos ~ 07950-526592
A20LEE
Post by A20LEE » Thu Mar 26, 2009 8:31 pm
job for the weekend i think.
jimbo1234567
Post by jimbo1234567 » Thu Mar 26, 2009 8:41 pm
they are a bitch to get off though
