RS4 B5 Wheels onto S4 w/ std calipers?
Just put a post about RS6 Reps but have come across a set of genuine RS4's B5 that i would happily have.
They are supposidly genuine with part numbers 4D0 601 025 AH
in an 18x8 ET43, does anyone know if these will go straight over the standard B5 S4 calipers?
Sure it must have been done may times before but i wanted to be sure before buying them as i dont want to fit spacers.
Kyle
Kyle
Blue_Thunder
- Top Gear
RE: RS4 B5 Wheels onto S4 w/ std calipers?
Genuine B5 RS4 wheels have ET20.
thanks, have done loads of digging about and it seems that those for sale are not genuine RS4's.
those that have put reps on have gone for an ET35 (18x8) but even still may need a small spacer to clear the calipers (especially with new discs and pads as the outer part of the caliper sits out further).
have decided that the reps are the way to go and will order the ET35's and hope its close - but will fit a 3mm spacer if needed, not ideal but not too bad either...
anyone care to comment?
you will need a 5mm spacer if your pads are decent, if your pads are like new you will need to grind a wee bit off your caliper with the 5mm spacer.
its a pain in the dot
thanks for that curtis. the wheels should arrive today. i have a 3mm and 6mm spacer to play with at home so hoping that they should go on without much grief...
Yep B5 reps. I know there are varying standards of wheel as with most things. The reps on mine are the relatively more expensive ones from Italy I think. There are some cheapo ones from China. Maybe it's the spokes themselves that cause the issue on some!curtis11 wrote:interesting , could depend on the make of the replica.
they are b5 reps?
[/img]UPDATE:
for completeness of this post i thought i'd let people know what i found...
i bought a set of reps from Elite Direct - 18x8 ET35, 225/40/18 tyres Toyo Proxes.
the rears were fine.
fronts needed 6mm spacers to go over the calipers (std S4 calipers) with fairly new pads (1 month) and older discs (8 months)
i plan on shaving some of the calipers away to allow me to put a 3mm spacer on the front as the wheels are sticking out of the arch. this isnt a problem at the moment but may be when i get the car lowered.
Dazzer:
is yours lowered? and what did you go for?
i was planning on just doing a set of springs, i saw some that were 25mm front and 15mm rear. that should make it sit as it should as opposed to the 'arse low' look...
Dazzer:
Users browsing this forum: Majestic-12 [Bot] and 79 guests
