Hi all,
Just got my car back from Unit5 in kent, having had them try to get the engine mangement light to go out. Picked it up got half a mile it was back on.
It registers a fault code of 16985/p0601/001537 and can be cleared, however it appears again almost straight away, the reference i have found for this is at http://wiki.ross-tech.com/index.php/16985/P0601/001537 although that car seems to run faultlessly.
I'm now terrified that i need some VERY expensive repairs, having just brought the car i'm probably panicking needlessly, but can anyone shed any light on this, and/or any possible solutions? If i do need a new ECU, how much does one of those cost?
P.S. Just had an N115 (evap) canister purge solenoid valve any ideas what that is, what it does, and or should i worry about that aswell.......lol
Many thanks in expectation and trepidation,
Paul.
Fault code
- PetrolDave
RE: Fault code
The link you give has different suggestions depending on what engine you have, but you don't tell us that information...
- mattykerby01
RE: Fault code
Can you copy and paste the complete code.
In Maidstone maybe able to help and i have VAG COM
Matt
Matt
RE: Fault code
hey paul - solution is simple - your car needs to go to dealer for an SVM (software upgrade) of the ECU. DO NOT replace ECU, as this isnt necessary - im at AUDI dealer in South Africa
RE: Fault code
sorry for delay in posting back here, lost the thread. The car is a 52 plate RS6
Nice green 52 plate RS6
1974 Triumph Stag
1994 Landrover 110 CSW
Volvo V70
Pro photographer, weddings, parties, cars, track days, portraits or anything photograhic catered for, event Photography a specialty.
www.medwaystudio.co.uk
paul@medwaystudio.co.uk
1974 Triumph Stag
Volvo V70
Re: RE: Fault code
Did you get this sorted? Did you visit your local dealer for the above mentioned SVM? Just asking as I read elsewhere that this will not cure the problem.raceman wrote:sorry for delay in posting back here, lost the thread. The car is a 52 plate RS6
RE: Re: RE: Fault code
no, still got the light on, but it seems to run just fine, but would like to get it to go out, it does bug me
1974 Triumph Stag
Volvo V70
1974 Triumph Stag
Volvo V70
