VAG-Com Newbie 17547 code query
Diagnostic Trouble Codes (DTC) / VCDS (VAG-COM) forum
onlinesys
Post by onlinesys » Sun Mar 08, 2009 11:10 am
Emission warning light on (intermittent)
40 days ago, clear code.
30 days ago, oil change, spark plugs change, oil/air filter change
14 days ago, emission warning light on again and 3 days later gone!
Today back on again. VAG-Com cable connected:
P1139 Long Term Fuel Trim Add.Fuel,Bank2 System too Rich 17547
(intermittent)
Code cleared!
Any clue?? MAF, o2 sensor??
The car seems not as smooth as usual if the Emission light is on??!!
Thanks for your help in advance :oops:
onlinesys
RE: VAG-Com Newbie 17547 code query
Post by onlinesys » Sun Mar 08, 2009 2:32 pm
The exact wordings from the VAG-Com :
17547 - Fuel Trim: Bank 2 (Add): System too Rich
P1139 - 002 - Lower Limit Exceeded - Intermittent
Thanks again for your insight
PetrolDave
Post by PetrolDave » Sun Mar 08, 2009 5:05 pm
Can't shed any light on that code, but when the Check Engine light is on the SW goes into a default mode so the engine won't run as well as usual.
Contigo
Post by Contigo » Mon Mar 09, 2009 2:40 pm
2001 Avus Silver RS4 B5 60k on clock, MRC Custom Remap, Sunroof, Bluetooth prep
2006 Daytona Grey RS4 B7, RNS-E - SOLD
2006 BMW M6 - GONE
onlinesys
Re: RE: VAG-Com Newbie 17547 code query
Post by onlinesys » Tue Mar 10, 2009 3:10 am
Thanks Contigo! i did do a search and reckon it is most likely MAF related.
since it is intermittent, I do think if the MAF is dirty and might try to clean it. However, my garage told me the MAF on the RS6 is not cleanable????!!
Is it true? :roll:
onlinesys
RE: Re: RE: VAG-Com Newbie 17547 code query
Post by onlinesys » Mon Jun 01, 2009 10:47 am
Just used a generic code reade connected to the OBD II connector and got this message.
PO160 02 sensor CKT no activity, Bank 2 Sensor 2
Any suggestion on where is the source of problem?
Return to “DTC / VCDS”
