BRAKE DISCS
BRAKE DISCS
Hi
Can anybody sdvise where i can get drilled brake discs for a 2003 RS6 apart from Audi.
RE: BRAKE DISCS
Thanks, i will be giving them a call
Cornishmoocher
- Top Gear
RE: BRAKE DISCS
What he said ^^
It's all Bollox.
RE: BRAKE DISCS
Hi,They do a 390mm brakes conversion.This will still fit behind the standard 19" wheel and standard calipers.It comes with a fitting kit which allows the caliper to take the larger disc,and discs are drilled.kit is about £950 to buy.They also advised braking ducts for cooling and said that they are a well worth while mod.
RE: BRAKE DISCS
dsgwagon on ebay
Now : XFR Jag 5.0 Supercharged
Used to have : C5 Daytona Avant , silver leather , carbon inserts ; RNSE, TV in motion, Bluetooth , well filled SD card slots ; PSS9's ; Hotchkiss ARB's ; Miltek cat back res ; Wagner intercoolers ; Phaeton brake ducts ; forge DV's ;
RE: BRAKE DISCS
Worth getting a quote from Virdee Autos too
RE: BRAKE DISCS
Thanks for the help,They could only get the Audi parts, Cheers anyway.
Cornishmoocher
- Top Gear
RE: BRAKE DISCS
I have the u20 big brake kit and its awesome. Well worth the money.
It's all Bollox.
RE: BRAKE DISCS
Why do you want non Audi parts?
Cornishmoocher
- Top Gear
RE: BRAKE DISCS
He may have been refering to the fitting kit that you need.....
It's all Bollox.
RE: BRAKE DISCS
Did you have this brake kit fitted at Unit 20 ?
Cornishmoocher
- Top Gear
RE: BRAKE DISCS
YUP.
It's all Bollox.
Users browsing this forum: Bing [Bot] and 104 guests
