New Owner - think a sensors on the blink....
BERGS2
Post by BERGS2 » Thu Mar 05, 2009 1:37 pm
...Hi Guys - well - Ive rackup up a fair few miles in the beast since picking it up last weekend, and stumbled on my first problem. :(
Cruising home from work last night - doing about 50 on the A3 (it was wet) the EPC light and traction control light come on and the car went into what I can only assume was a 'limp home' engine map....
pulled over within 1/4 mile or so and turned the engine off.
restart - no issues no wanting lights and the full 414 horses on tap...
assume this is a wheel speed sensor or similar?
Should i call audi assist or just run it to a local dealer for diagnosis?
anyone else experienced similar?
ta in advance!
PetrolDave
RE: New Owner - think a sensors on the blink....
Post by PetrolDave » Thu Mar 05, 2009 1:56 pm
See if it happens again.
Do a check with VAG-COM and see what intermittent fault(s) were logged.
Could be any one of many sensors, not just a wheel sensor. Since it was wet I wonder if some water spray got into an electrical connection?
BERGS2
Post by BERGS2 » Thu Mar 05, 2009 3:42 pm
Thanks Dave - how do I do a check with VAG-COM?
BERGS
tartan_rob
Post by tartan_rob » Thu Mar 05, 2009 3:56 pm
You need to buy VAG-com. Either find a fellow RS246 member with VAG-com and ask for assistance or goto your local dealer. I assume the car is under warranty so no issues either way,.
2017 Kawasaki Z1000
2014 RS6
2014 S1
primus2211
Post by primus2211 » Fri Mar 06, 2009 4:14 am
Just ran into similar problems a couple of weeks back. The error turned out to be "Brake Switch Failure: Intermittent".
The workshop swapped out the switch located on upper end of the brake pedal and for the last couple of weeks it has been OK.
Users browsing this forum: Google [Bot] and 208 guests
