I have installed an RNS-E in my RS6 and want to strip out the remaining RNS-D bits (TMC and TV Tuner).
To remove the TMC do I disconnect it and then pair/connect the radio wires together. Is that all I need to do before physically removing it?
To remove the TV tuner I presume it is just a case of unplugging and removing?
Grant
Removal of TMC/TV tuner from RS6
RE: Removal of TMC/TV tuner from RS6
Pretty much what you have said, but did you connect the RNS-E directly to the cluster for can bus?
Re: RE: Removal of TMC/TV tuner from RS6
Yep, indeedy.craigyb wrote:Pretty much what you have said, but did you connect the RNS-E directly to the cluster for can bus?
