You will see that this exhaust comes in 4 pieces plus unions so will fit inside an average saloon/hatchback/estate.
Can be collected from Fleet, Hampshire or possibly from an Audi meet subject to arrangement.
CheeRS!
Grant
try www.parcel2go.com they are very cheap and is done through DHL I use them all the time.GardinerG wrote:Ok, rough size for package: 150cm x 70cm x 20cm, it may be cheaper to send it in 3 parcels. Presumably you need the weight - which I try to get a bit later.
Grant
marmite wrote:try www.parcel2go.com they are very cheap and is done through DHL I use them all the time.GardinerG wrote:Ok, rough size for package: 150cm x 70cm x 20cm, it may be cheaper to send it in 3 parcels. Presumably you need the weight - which I try to get a bit later.
Grant
