..indeedDidn't you buy yours from NJ?
My view is that there will always be something you don't expect however much you check it over so find out as much as you can and negotiate accordingly.Perhaps i'm just too anal then. When I bought my car it had no major DTC's. (Alarm codes from window being open and a radio based fault).
My neighbour did say I am a fanatic.....
neckarsulm wrote:So did you buy it then?![]()
Makes the one I saw last week sound good.
So what's the reg so others can avoid it?
so it needs 2 EGTs - always thought the RS4 had one, S4 had two![]()
I bet it didn't go well with a duff EGT.
If that other bloke wasn't such a tw@t i'd make an offer.....neckarsulm wrote:So did you buy it then?![]()
EGT, how much are those each?neckarsulm wrote:So did you buy it then?![]()
Where are you? Come and have a look/drive of mine. Even if it's just for referencehonahon wrote:If that other bloke wasn't such a tw@t i'd make an offer.....neckarsulm wrote:So did you buy it then?![]()
back to square 1........
Hi mate.mikeyquattro wrote:Where are you? Come and have a look/drive of mine. Even if it's just for referencehonahon wrote:If that other bloke wasn't such a tw@t i'd make an offer.....neckarsulm wrote:So did you buy it then?![]()
I think it was £150 for my B5 S4 and prob the same for RS4EGT, how much are those each?
There are 2 EGT sensors as the temps need to be measured for each bank.neckarsulm wrote:So did you buy it then?![]()
honahon wrote:![]()
VAG-COM Version: Release 409.1-US
Chassis Type: 8D - Audi A4 B5
Scan: 01,02,03,08,15,17,25,35,45,55,56
Address 01: Engine
Controller: 8D0 907 551 K
Component: 2.7l V6/5VT G 0001
Coding: 10711
Shop #: WSC 63351
WUAZZZ8DZ1N904636 AUZ7Z0A1786730
6 Faults Found:
16684 - Random/Multiple Cylinder Misfire Detected
P0300 - 35-10 - - - Intermittent
16687 - Cylinder 3 Misfire Detected
P0303 - 35-10 - - - Intermittent
16689 - Cylinder 5 Misfire Detected
P0305 - 35-10 - - - Intermittent
17862 - Exhaust Gas Temp Sensor 1 (G235): Short to Ground
P1454 - 35-00 - -
17866 - Exhaust Gas Temp Sensor 2 (G236): Short to Ground
P1458 - 35-10 - - - Intermittent
17539 - Oxygen (Lambda) Sensor: B2 S1: Internal Resistance too High
P1131 - 35-10 - - - Intermittent
Readiness: 0000 0000
Address 03: ABS Brakes
Controller: 8D0 907 389 E
Component: ABS/ESP allrad D56
Coding: 04395
Shop #: WSC 02325
No fault code found.
Address 08: Auto HVAC
Controller: 8D0 820 043 P
Component: A4 KLIMAAUTOMAT D58
Coding: 00061
Shop #: WSC 63351
Skipping Address 15-Airbags
Address 17: Instruments
Controller: 8D0 920 981
Component: B5-KOMBIINSTR. VDO D13
Coding: 00464
Shop #: WSC 00001
Address 25: Immobilizer
Controller: Bit teA dre ss
Component: e 17 eingeben
No Faults Found
or DTCs not supported by controller
or a communication error ocurred
Address 35: Centr. Locks
Controller: 8D0 862 257 E
Component: CV-Pump, Alarm, RC D17
Coding: 15178
Shop #: WSC 63351
6 Faults Found:
01371 - Alarm triggered by Door Contact Switch: Driver's Side
35-00 - -
01370 - Alarm triggered by Interior Monitoring
35-00 - -
01365 - Lock/Unlock Switch: Interior
29-00 - Short to Ground
01389 - Tailgate Open Switch (F124)
00991 - Interior Lights
28-00 - Short to B+
00956 - Key 2
09-00 - Adaptation Limit Surpassed
Address 45: Inter. Monitor
Controller: 4B0 951 173
Component: Innenraumueberw. D03
Coding: 00102
Shop #: WSC 63351
Address 55: Xenon Range
Controller: 4B0 907 357
Component: LEUCHTWEITEREGLER D004
Coding: 00012
Shop #: WSC 63351
Address 56: Radio
Controller: 8D0 035 195
Component: Radio D00
Coding: 00010
Shop #: WSC 63351
1 Fault Found:
00850 - Control Output Active: Radio Amplifier
29-10 - Short to Ground - Intermittent
End --------------------------------------------------------------------------------------------------
and.........................................
cracked front and back bumper.
alloys ALL kerbed with dodge silver cover up marker pen
leather, blue stains in back seats (kids for sure) cracked, dull, drivers side almost black creases.
weird humming noise from centre console
back pads and disks both shot
dent on bonnet above Audi badge
keyed boot, from tail to brake lights
passenger seat upholstery detached from seat.
Pulls to the left under braking........
No Log book (in the office apparently)
No bill for supposed new clutch
No new turbos (as promised)
NEED I CONTIUNE......................................................................
