gearbox remap question
Does anyone know the answer to this question ?:
If you have your gearbox remapped by someone like MRC, then does the gearbox ecu have to be taken out and re-soldered back on ? or is the process the same as simply plugging into the main ECU port? (no removal and then soldering involved)
Steve G
Steve G
RE: gearbox remap question
As you said SteveG.....board out....old chip removed, new chip soldered on.....done
RS6 (MRC'd with econodrive) is not just for Xmas
Toyota Aygo Platinum for minimising carbon footprint.
The ecu has to be removed and the chip soldered .
Unit 20
0151 3366888
0151 3366888
I can't see the tech removing the trim , lifting the carpet , removing & open the plastic box that lives under the carpet & then working out the chip has been changed ..
Unit 20
0151 3366888
0151 3366888
is it worth remapping the gearbox without remapping the engine ?
Now : XFR Jag 5.0 Supercharged
Used to have : C5 Daytona Avant , silver leather , carbon inserts ; RNSE, TV in motion, Bluetooth , well filled SD card slots ; PSS9's ; Hotchkiss ARB's ; Miltek cat back res ; Wagner intercoolers ; Phaeton brake ducts ; forge DV's ;
We usually don't offer gearbox remaps for standard cars. This could encourage people to get their engines remapped by other tuners and then come to us only for the gearbox remap, which we are just not interested in. The stage2 gearbox remap is something we have developped for our customers and because we are the only ones who offer this on the market, this is a bonus we keep for our customers only.
thats what i was thinking , get the improvement without doubling your insurance
Re: gearbox remap question
No one in the world can flash a tiptronic ECU through OBD2 as far as I'm aware, I don't even think the ECU supports it...SteveG wrote:Does anyone know the answer to this question ?:
Steve G
As for how visible it is, I can solder so no one can see that the chip has been soldered before or not.
Do the MTM TCU chip, no need for ECU 'til you're ready. I did mine, shifts fast and smooth.SteveG wrote:That is exactly what I was wondering, so that I perhaps get better economy and faster change down/up.philroach wrote:is it worth remapping the gearbox without remapping the engine ?
2003 AUDI RS 6 / Mugello Blue - US Spec / Silver Interior / FULL Cat-less non-res Milltek / Wagner IC's / Unitronic Custom Tune
S2tuner wrote:No one in the world can flash a tiptronic ECU through OBD2 as far as I'm aware, I don't even think the ECU supports it...SteveG wrote:Does anyone know the answer to this question ?:
Steve G
I didn't mean remapping the gearbox via the OBD2 port, I was asking if it was a similar process (via a similar plug in cable method)
tartan_rob
RE: Re: gearbox remap question
Minhea - you talk about stage2 gearbox map....what have I got?
2017 Kawasaki Z1000
2014 RS6
2014 S1
2014 RS6
2014 S1
Re: RE: Re: gearbox remap question
You have the stage 2 gearbox map, RobTartan_Rob wrote:Minhea - you talk about stage2 gearbox map....what have I got?
Users browsing this forum: Majestic-12 [Bot] and 272 guests
