Port status OK
Interface not found
Does this just mean it's not plugged into the car as the error on ross tech is not the same as I should be getting
J
I've done that, changed it to COM port 1Contigo wrote:It's because you haven't defined the com port for the USB cable. Go into device manager and then find the USB serial controller. Right click properties and then select advanced. Select a COMport from the drop down list (below 5 I think) and then click apply.
Once done run vagcom again and then make sure that you have gone into the setup tab and selected the corresponding COM port.
I got it from the exact same chap as you recommend from ebay.. I've defined as COM1 and it can see the port and up in device manager... It dint load VCS???Contigo wrote:It's a USB-serial type which you have to define as COM rather than USB, it's the same cable as mine I think.
No, I'm testing without being plugged into a car, but it should still find the interface without it?...... I think......Contigo wrote:Don't need VCS.
Set it to COM2 and retry, the change to COM2 in option tab and then press test. Is your ignition on too when you hit test?
Contigo wrote:No, doubt it, it's lookin for comms at both ends mate.
Users browsing this forum: No registered users and 156 guests
