heated seats
Hanging down from the seat itself you mean?
Also got any links to fleabay on the climate control unit i'd need?
Cheers,
Russ
Cheers,
Russ
Evo VIII long gone
B5 S4 Avant long gone
Astra CDTI estate with 2 blown gearboxes long gone
BMW M Sport 320d Business Edition tourer the chariot of choice (with DMF about to die) gone
B8 S4 Avant is now the chariot of choice
I doubt there will be a plug! However, I remember that the plugs were all coloured.
Take you seats out, if your seats have more plugs that your wiring loom, then you're in luck!
http://cgi.ebay.de/Audi-A4-B5-Klimabedi ... 240%3A1318
It will be a green plug the same size as the red plug which will be there for the power seats. I fitted my Rs4 seats then ran the car without the heaters untill i got the relevent bits to get it sorted. On the prefacelift the seat heater buttons are on either side of the fog, hazard switches. and the drivers switch is where the Cubby hole is now. I just changed the whole center console to facelift and bought a new climate control with the switches. The loom was from Kufatec which was very simple to fit just a bit fiddley. Good luck
Wide Body S4
