Battery Change
Diagnostic Trouble Codes (DTC) / VCDS (VAG-COM) forum
ste4ie
Battery Change
Post by ste4ie » Sun Jan 11, 2009 1:31 pm
Posted this on S4 forum, suggested I try here
Changed the battery a few days ago after an unexpected failure. The S4 has a couple of problems since.
Air bag light comes on after about 4 miles, goes out again when ignition is turned off and on again.
The #1 trip computer has dissapeared completly, #2 is there, but when i try to scroll through to get trip 1 data, its not there at all.
I did perform the Key syncro after fitting the new battery, so everything else is fine.
Any thoughts is it a trip to the dealer or purchase VAG-COM.
S4 2003-b6
If I purchased Vag, as a novice, would I be able to clear these Faults or does it take some experience to get into VAG ?.
Cheers Steve
mikeyquattro
RE: Battery Change
Post by mikeyquattro » Sun Jan 11, 2009 1:37 pm
have you looked here
http://rs246.com/index.php?name=PNphpBB ... ic&t=51359
to see if there is anyone in your area with vag-com who could help?
Tomorrow is another day
ste4ie
Post by ste4ie » Mon Feb 09, 2009 9:00 pm
Ok, have purchased Vag-com, and airbag fault now sorted, but no luck with restoring the 2nd Trip data, ideas anyone ?.
Have checked the instrument set up and it is set to uk spec i think
Address 17: Instruments Labels: 8E0-920-9xx-8E2.lbl
Part No: 8E0 920 980 L
Component: KOMBI+WEGFAHRS. RB4 D36
Coding: 01400
Shop #: WSC 00779
Part No: 59232
Component: AUZ6Z0C0013093
59232 AUZ6Z0C0013093
No fault code found.
2003 b6 S4
Steve
PetrolDave
Post by PetrolDave » Tue Feb 10, 2009 1:12 pm
Try looking at the label file on the Ross-Tech wiki here http://www.ross-tech.com/vag-com/downlo ... xx-8EC.lbl
It looks like you need to modify the value in adaptation channel 19 of address 17 from x0xxx to x1xxx.
ste4ie
Post by ste4ie » Tue Feb 10, 2009 10:59 pm
PetrolDave wrote:Try looking at the label file on the Ross-Tech wiki here http://www.ross-tech.com/vag-com/downlo ... xx-8EC.lbl
Thanks PetrolDave,
looks promising, as i am very new to all this, only used vag-com once, i am not sure exactly how to do what your suggesting, but will have a go the weekend. Thanks for the info
Cheers Steve
ste4ie
Post by ste4ie » Sat Feb 14, 2009 9:43 am
Thanks mate you were spot on. all sorted now :D . Dont know what the cost at the dealer would have been to resolve these two faults, but think that the VAG-COM has paid for itself already. Thanks again.
Cheers Steve
Return to “DTC / VCDS”
