4 wheels with conti sport contact3 tires. 2 tires nearly new, 2 tires legal with a few mm.
wheels are uncleaned - marks as per pictures
£850 with 4 rs4 wheels exchange(no tires) or £950 as they are. They come with the spacers required.
Sportec 19" x 9.5" Wheels
http://www.MRCtuning.com
RE: Sportec 19" x 9.5" Wheels
4th wheel. tires are 255/30x19
are you sure these are 9.5" wide - I can't find a listing for 19x9.5 on sportec's website?
Also what's the offset? Is it ET42 with 20mm spacers ?
thanks
Olly
thanks
Olly
- Virdee Autos
- Trader (Expired)
I think these are usually 10J for the RS4, along with 15mm spacers on either side IIRC
Virdee Autos ~ 07950-526592
I am not sure! I measured with a tape measure - they are not as wide as some as i have seen - some sportecs look really wide for the tyres. When the car comes back from the fab shop i will pull a wheel off and check..
Re: RE: Sportec 19" x 9.5" Wheels
It's true sportec make a 10" wide rim but wouldn't a 255 tyre be stretching it a bit (scuse the pun!). I suspect these are 19x8.5 with an ET42, but thanks Doug for confirming (when you do!)Virdee Autos wrote:I think these are usually 10J for the RS4, along with 15mm spacers on either side IIRC
Olly
RE: Re: RE: Sportec 19" x 9.5" Wheels
Are these still available?
yes
