Clutch Problem
2.7 V6 30v biturbo - 380 bhp
gezzerS4
Clutch Problem
Post by gezzerS4 » Tue Feb 03, 2009 10:10 pm
I have what I think is a slipping clutch, it has some strange symptoms though.
For instance it follows the normal worn clutch diagnoses of slipping in high gear say 5th or 6th and when accelerating hard, revs rise about 1000 but then without backing off it bites back in and pulls hard without slipping again, until you do back off and do it all again.
Most clutch slips I have experienced in other cars continue to slip once they start until you throttle back.
If cruise is engaged and I manually accelerate it will also dis-engage cruise control, I am presuming this is a safety feature where engine revs do not match engine speed Vs Gear/Road speed expectations.
Any ideas??
RS4 Avus Silver, HiTech Interior, Stage 3, Milltek & Cats, H&R, Sportec ARB's, Forge DV's
quattrokid1
RE: Clutch Problem
Post by quattrokid1 » Tue Feb 03, 2009 10:43 pm
no but contact Grizz, perhaps he can help you
Misano red B5 RS4 710 D/V's SERVICED BY EL GRIZZMO:).... Wife's !!
Tornado red WR quattro :):)
UrS4 saloon auto:) resurected by Unit20
Audi S3 8L Imola yellow
Audi B6 S4 Cabrio SOLD :( :(
Audi 100 2.2E SOLD
Audi 80 cabrio 2.6 V6 (SOLD)
Audi 90 quattro SOLD
imolas4uk
RE: Clutch Problem
Post by imolas4uk » Tue Feb 03, 2009 11:59 pm
sounds like it needs a clutch to me,maybe the friction plate is contaminated with oil or brake fluid or even coolant and whenn some slip occurs it burns it then grips again ?,you wont know till you get the box out,stop driving it though before your flywheel is fecked,cruise will dissengage when you accelerate with the pedal or brake
1999 S4 bi turbo imola yellow,grey pearl wheels,now with KO4's.
2001 A6 avant 2.5 tdi,the work horse
mbelle
RE: Clutch Problem
Post by mbelle » Wed Feb 04, 2009 12:52 am
My cruise doesn't disengage when I manually accelerate - when I drop to the set speed, it holds it again.
Mine only disengages when I either brake, cancel it using the lever, or drop my clutch.
Marcus
Current: A C6 Audi
Previous: A B5 Audi
Norrs2
Re: RE: Clutch Problem
Post by Norrs2 » Wed Feb 04, 2009 10:44 am
mbelle wrote:My cruise doesn't disengage when I manually accelerate - when I drop to the set speed, it holds it again.
So does mine!
@gezzerS4:-
I had to replace the Clutch in mine last year. I quickly changed down to third one day with a fully loaded car to overtake and the revs just rised dramatically with no forward momentum and when I backed off the throttle all was normal after that. (I know your's is behaving slighlty different but still seems intermittent like mine) I tried inducing it when I was on my own a couple of times and it wouldn't do it. TBH I was frightened to try too much incase I completely fooked it. Just took it to Audi stealer shortly after and got the Clutch changed - no problem since. Sounds like you could have a similar problem! :cry:
B5 RS4 - Santorin Blue Pearl
B7 Brakes
MRC Custom Re-Map
Loba Camshafts
Wagner Downpipes
Miltek Cat Back SS Exhaust
1988 Pearl White MB Ur quattro (Genesis)
