B6/B7
The B7 came in at the beginning (March IIRC) of 2005, I received one of the last B6's in December 2004.
Apart from cosmetic changes affecting the body panels and lights, the B7 has quad exhaust system which actualy sounds better than the OEM B6 and means some people didn't feel the need for a Milltek. The biggest difference was that the B7 received rear Trapezoidal suspension and hub assemblies and the way you can tell is that with the B6 you can only upgrade to the B7 RS4 brake assembly at the front but with the B7 S4 you can upgrade the front and rear calipers/disks/pads
I would agree with P G, I liked the B6 shape better than the B7 particularly the grill. The interiors to me are identical (have owned both a B6 and B7 S4) and most of the changes are cosmetic to the exterior or otherwise hidden. I did notice that the dipped headlamp beams wobbled over bumps in the B6 but don't in the B7 (checked on the same bit of road)
I still have the view that the B6 was a little less refined than the B7 and felt more raw and involving to drive but both good cars.
Pete
Pete
Owned three B6's but never driven a B7 one. The B6 was prone to leaking auxillary radiators which is, apparently, fixed on the B7. You will struggle to find a manual B7 as most punters upgraded to an RS4 as the residuals were better so leasing costs etc were very similar.
Maserati GranTurismo GTS Auto, S3 Sportback, TT2 3.2 Roadster, Disco3 for the heavy stuff.
cabin is identical; outside is similar, prefer B6 front as the B7 big grill is ugly as hell; except in RS form.
Not sure on the technical upgrades, im sure the B7 is more refined but surely there is limit to the upgrades Audi could make from the same base?
It it were my money, i'd be in a B6, but make sure it has RNSE sat nav
The aux. rad. problem in the B6 was alleviated by the revised front bumper design on the B7. Having had a B6 I only had one rad. fail on me but with regular cleaning out of the rad. ducts (where the foglights are) with a pressure washer never had the problem again. It is usually an accumulation of dead leaves and road grime corroding the rads and connecting pipes.
- BlingBling
