Vagcom results...
Diagnostic Trouble Codes (DTC) / VCDS (VAG-COM) forum
ogg14
Vagcom results...
Post by ogg14 » Wed Jan 28, 2009 3:48 pm
I ran tests 002, 115 and 118... I realise now that i should have done 002 instead of 003... I will do this again on tuesday as am away to Ireland for 4 days...
Here goes... any comments would be appreciated...
Wednesday 28 January 2009 13:22:23
8D0 907 551 C 2.7l V6/5VT 0002
Group A: '002
Engine Speed Engine Load Injection Timing Mass Air Flow
TIME (G28) (G70)
Marker STAMP /min % ms g/s
0.01 2120 107.5 10.54 71.06
0.5 2320 133.8 12.92 96.89
1.01 2560 160.9 14.62 130.28
1.61 2880 176.7 17.34 151.47
2.11 3160 185.7 18.36 173.89
2.62 3480 184.2 18.02 187.36
3.13 3720 182 19.72 199.39
3.62 4000 172.2 19.04 199.25
4.14 4280 167.7 18.36 206.19
4.67 4520 163.2 18.02 215.03
5.22 4760 157.9 17.68 217.81
5.78 5040 149.6 17 219.69
6.35 5280 147.4 17.34 225.19
6.93 5560 143.6 16.32 232.64
7.53 5800 139.8 15.64 235.19
8.14 6000 134.6 14.62 235.28
8.76 6240 131.6 14.28 239.19
9.39 6440 127.1 13.6 240.53
10.02 6640 124.8 13.26 241.19
10.65 6800 121.1 12.58 243.83
11.29 6840 55.6 5.78 103.89
11.88 5960 9.8 1.36 14.61
Wednesday 28 January 2009 13:26:13
Group A: '115
Engine Speed Engine Load Boost Pressure Boost Pressure
TIME (G28) (specified) (actual)
Marker STAMP /min % mbar mbar
0.01 1960 69.9 1000 1200
0.5 2080 99.2 2250 1220
1.01 2280 121.1 2210 1380
1.51 2480 141.4 2140 1580
2.11 2760 166.2 2180 1860
2.72 3080 178.9 2220 2010
3.22 3320 181.2 2170 2030
3.72 3600 176.7 2100 2050
4.22 3840 176.7 2060 2090
4.74 4120 170.7 2010 2060
5.26 4320 166.9 1960 2010
5.79 4560 163.2 1930 1970
6.33 4800 157.1 1900 1920
6.89 5040 151.1 1850 1870
7.46 5280 147.4 1820 1840
8.05 5480 142.9 1790 1780
8.64 5720 139.1 1750 1770
9.25 5920 136.1 1720 1730
9.86 6120 131.6 1720 1720
10.49 6320 127.8 1720 1710
11.12 6480 125.6 1720 1710
11.75 6640 124.1 1740 1710
12.37 6800 121.8 1740 1720
13.02 6800 39.1 990 1420
13.59 5200 12.8 990 1130
Wednesday 28 January 2009 13:28:24
Group A: '118
Engine Speed Intake Air Wastegate (N75) Boost Pressure
TIME (G28) Temperature (G42) Duty Cycle (actual)
Marker STAMP /min °C % mbar
0.01 2200 28 63.1 1450
0.5 2440 27 45.5 1570
1.11 2720 27 72.9 1660
1.61 2960 27 69 1920
2.11 3280 26 71 2030
2.61 3560 26 70.6 2020
3.13 3840 26 71.8 2070
3.64 4080 27 69.8 2020
4.16 4360 27 67.8 1980
4.68 4600 27 67.5 1930
5.23 4880 29 67.5 1880
5.8 5120 30 67.5 1840
6.37 5400 30 67.5 1790
6.96 5640 32 67.1 1790
7.57 5840 33 66.7 1740
8.18 6080 35 66.3 1710
8.8 6280 36 66.7 1710
9.43 6480 37 67.1 1710
10.06 6680 39 67.1 1700
10.69 6800 39 40.4 1860
11.32 6800 39 0 1250
11.9 5520 37 71.4 1010
Please advise me of any troubles or problems...
Many thanks
Andy
Sebastian
RE: Vagcom results...
Post by Sebastian » Fri Jan 30, 2009 3:20 am
There must be a reason why you ran the log, its hard to look at a log without any context/issues.
Sebastian @ Ross-Tech.com
ogg14
Post by ogg14 » Sun Feb 01, 2009 10:22 pm
I ran the logs to see if i had any air leaks and just to log some results for the forum... I dont have any issues as such but i have posted my logs on another forum... I have had several responses to the logs...
All i was interested in was if my car was running okay... I am new to the Vag-com and wasnt sure how it worked...
Can you give any advise if there are any issues with my logs... Timing etc...
Thanks Sebastian
Andy
mylife98
Post by mylife98 » Mon Feb 02, 2009 1:40 pm
Hi,
I'm pretty new to VAG Com myself, but trying to learn!
I've uploaded the following which might well help you. Page 15 onwards. It's the Audi tech guide for how to read VAG Com for boost checking, how to check for errors, the tolerances etc.
I haven't done it myself so can't offer much advice but on reading it seems pretty straight forward. Let us know how you do.
http://www.mylife98.plus.com/Audi_A4_B5 ... harger.pdf
Audi B5 RS4 Standard. Avus Silver. Debadged. Supaglass.
Return to “DTC / VCDS”
Users browsing this forum: No registered users and 40 guests
