Ignition derived 12v supply
MartynC
Post by MartynC » Wed Jan 28, 2009 5:01 pm
Is there a point under the bonnet of my RS6+ were I can easily connect to that will supply 12v (less than 1 amp) when the ignition is on? i can find this in the fuse box in the car of course but then need a route into the engine bay. Any help appreciated.
MartynC
craigyb
RE: Ignition derived 12v supply
Post by craigyb » Wed Jan 28, 2009 6:19 pm
Under/behind the drivers kick plate you will find some metal bars, the one marked 75 is a switched live.
MartynC
Post by MartynC » Thu Jan 29, 2009 1:00 pm
Craig that's most useful thanks. What is the best route into the engine bay? I'm fitting led running lights.
MartynC
Blue_Thunder
Post by Blue_Thunder » Thu Jan 29, 2009 1:54 pm
Via the ECU box.
MartynC
Post by MartynC » Fri Jan 30, 2009 8:18 am
Thanks Guys......I'll get onto it to get my front leds lit!
MartynC :D
tartan_rob
Post by tartan_rob » Sat Mar 14, 2009 2:56 pm
There must be a ignition +ve from under the bonnet>>?
2017 Kawasaki Z1000
2014 RS6
2014 S1
MartynC
Post by MartynC » Sat Mar 14, 2009 5:19 pm
No doubt, but the bus mentioned is the right place and works well. Job done now, it drives a regulator (placed in the ECU box) for my LED driving lights.
MartynC
gdavison
Re: RE: Ignition derived 12v supply
Post by gdavison » Tue May 05, 2009 8:30 pm
craigyb wrote:Under/behind the drivers kick plate you will find some metal bars, the one marked 75 is a switched live.
Help .. is this also available in the C6 RS6 ? and forgive my ignorance .. whats a Drivers kick plate?
Return to “Electrical”
Users browsing this forum: No registered users and 83 guests
