Tired Springs?
2.2 I5 20v turbo - 315 bhp
DickyC
Tired Springs?
Post by DickyC » Mon Jan 19, 2009 9:33 pm
Are springs getting tired are common thing? Only - you know me, I may be imagining it - but she seems to be sitting a little low at the back.
The car that is, not the Countess.
:D
Volcano Black 1995 RS2. Standard.
Gone - but understood to be alive and well and living in Cornwall.
VaudiGR
RE: Tired Springs?
Post by VaudiGR » Wed Jan 21, 2009 8:47 am
Springs tend to 'sit' a bit after years of fatigue.I was told by a specialist shop that it is usually 15mm lower after some years.However my car sits lower although my springs have been replaced with new OEM 4 years ago,so this more or less happens quite fast.
If you realise however that the car only sits lower at the back,i would suspect faulty shocks as well,as the OEM shocks are easily damaged or worn and their rebound goes down easily.WHen i replaced mine with bilsteins,the car was actually lifted higher than the OEM appearance,and after about 5000kms it came back down to it's original height(after the shocks had been worked on a bit)
DickyC
RE: Tired Springs?
Post by DickyC » Wed Jan 21, 2009 9:57 am
Thanks, Vas.
I'll take it in to be looked at.
VaudiGR
RE: Tired Springs?
Post by VaudiGR » Thu Jan 22, 2009 1:24 pm
i was told that tired springs have no effect on the car's stability.it is normal fatigue and it wont create any problems(otherwise,every 5 years or so we would be replacing springs!!)
I have a used set that i modified to sit 15mm lower than original,heat treated and repainted.I havent put them on yet,but i will at some point to see differences
DickyC
RE: Tired Springs?
Post by DickyC » Thu Jan 22, 2009 9:31 pm
No, it wasn't the stability or anything, it's just the look of the car. It just looks as if it has sagged a bit.
Or has half a tonne of spuds in the back, that sort of thing.
VaudiGR
RE: Tired Springs?
Post by VaudiGR » Fri Jan 23, 2009 10:01 pm
as far as the looks is concerned,i always like it a bit lower to be honest !!
DickyC
RE: Tired Springs?
Post by DickyC » Sun Jan 25, 2009 11:25 am
If it was low at the front as well it would look better...
VaudiGR
RE: Tired Springs?
Post by VaudiGR » Thu Jan 29, 2009 12:00 am
hmm then you probably have damaged rear shocks....
DickyC
RE: Tired Springs?
Post by DickyC » Thu Jan 29, 2009 8:42 am
Stop, stop! I take it to see the man.
Other than that, it's behaving very well. All that money thrown at it last year did the trick.
afhgus
Re: RE: Tired Springs?
Post by afhgus » Thu Jan 29, 2009 4:32 pm
DickyC wrote:Stop, stop! I take it to see the man.
Hello Dicky
Couldn't pass by without saying don't panic, it does sound like the shocks have had there best days, glad all else is good.
A
M690LYY Volcano black,130000 miles,standard,everyday transport, new rear discs, new door trims, replaced radiators x2, front/rear shocks(OE) + suspension bushes, recent alarm, undersealed, new exhaust/head gasket, pulls like a train. for sale soon
DickyC
Post by DickyC » Thu Jan 29, 2009 7:58 pm
Hello Dicky
A
Hello Angus, how's things? How's life beyond the RS2?
There's a bit of a do down your way on the 8th of Feb if you fancy it. Tom, Al and I are all pencilled in. You are welcome to ride shotgun in mine. With the shocks on their way, it would be better balanced with two :D
PM me for details if you can do it.
Return to “RS2 (B4) 1994-1995”
