lights keep flickering
jacksrs4
Post by jacksrs4 » Fri Jan 23, 2009 2:28 am
my front lights keep flickering is there a cure or do i take it back to audi does this happen to anyone else. 8)
booski
RE: lights keep flickering
Post by booski » Fri Jan 23, 2009 9:17 am
Never heard of that problem mate, might be a dealer visit is in order.... Probably a simple electrical fix though, hopefully. Good luck
2007 RS4 (B7) Avant, Daytona grey
NonRes Milltek- SOLD......(missing her already)
pippyrips
Post by pippyrips » Fri Jan 23, 2009 12:38 pm
I had this problem assuming we are talking about the main beams?
It happened each time i drove over a manhole cover/uneven road etc.
The problem was cured by having two new headlight ecu's installed under warranty.
bn8959
Post by bn8959 » Fri Jan 23, 2009 4:06 pm
Is it both or just one? I had this with the xenons on my Mondeo (one would flicker a lot, then go out after a random amount of time). It was the Xenon bulb going, I left it too long and it eventually blew and took the ballast with it :(
Not sure if Audi will cover the bulbs under warranty, if not I got my replacement from www.hids4u.co.uk (that was for the Mondeo)- I think they are the same D2S type bulb in the RS4.
2016 C7 RS6 - Panther Black
Previous:
2008 B7 RS4 Avant, Phantom Black
pippyrips
Re: RE: lights keep flickering
Post by pippyrips » Fri Jan 23, 2009 4:49 pm
pippyrips wrote:I had this problem assuming we are talking about the main beams?
Just to add this was only happening on the drivers side.
jacksrs4
Post by jacksrs4 » Sun Jan 25, 2009 1:28 am
it happens to both, even driving straights, thanks :? for the advice, will contact dealer on monday.
wankeldude
Post by wankeldude » Sun Jan 25, 2009 4:26 am
mine just got fixed for that exact flickering issue. new ballast under warranty. If your service rep doesn't believe it or pushes you more towards new bulbs, just tell them to replace the ballast and if it still flickers, you'll eat the old ballast (literally, stick it in your mouth and swallow it)
Users browsing this forum: Google Adsense [Bot], Zyox and 424 guests
