This was discussed some time ago but afaik, in s-mode, the flaps will open at idle and again when the engine goes beyond 3500rpm. And yes, you can defeat this by doing a simple mod of plugging the vacumm hose and voila..your flaps will open all the time regardless of s mode or not, at all rev range.Driver32503 wrote:Question: I always thought that the S button opened the exhaust flaps 'all the time'. Is it true that it only opens them at idle, and only 'sometimes' at higher revs? If so, wouldn't a permanent flap-defeat keep the flap open all the time?
Park somewhere confined and you can hear the valves open at idle then close as you rev the engine.Ozrs4 wrote:This was discussed some time ago but afaik, in s-mode, the flaps will open at idle and again when the engine goes beyond 3500rpm
can't get owt for nowtDom81 wrote:So up to 20% throttle, you get LESS torque with Sport engaged? Never knew that...
As it's requested torque, not delivered, you presumably could actually get any shape you wanted including 100% output from only 1% input. Audi must have chosen the Sport mode curve to preserve driveability.NGS521 wrote:can't get owt for nowtDom81 wrote:So up to 20% throttle, you get LESS torque with Sport engaged? Never knew that...
Users browsing this forum: Google Adsense [Bot] and 73 guests
