Yeah, whatever did happen to, "the customer is always right"?SJ-RS4 wrote:I always end up getting int a "heated debate" when ever im at my local Audi Dealership,
Dynamic Ride Control...AGAIN
Re: RE: Re: RE: Dynamic Ride Control...AGAIN
Current
'10 Nissan GT-R Black Edition, Kuro Black.
'59 Scirocco 2.0 TFSI
'09 RSV4 Factory
'08 Aprilia SXV 550
Car park in the sky
'07 RS4, Phantom black saloon
'57 Clio 197
'04 Aprilia RSVR Factory. Black.
E46 M3 SMG, Alpine white
E46 320i coupe
E36 328is coupe
VW golf VR6
Screw you guys!' - Eric Cartman
'09 RSV4 Factory
'08 Aprilia SXV 550
Car park in the sky
'57 Clio 197
E46 320i coupe
E36 328is coupe
VW golf VR6
Ok, to put the record straighter on DRC. The version B7 RS4's have is DRC II, not the same system on the C5 RS6 but a strengthened parts version with higher pressure in it. As said previously the crap we in the UK have to put up with in terms of road quality will increase the pressure in a system that already runs at 12PSI and that causes 'weeping'
When your Audi technician has a look on their computerised technical bulletin system there are pictures which distinguish between when a shock is 'weeping' and 'leaking' and when the latter taht is when they are authorised to replace unless you have a friendly dealership who will fight your cause or eggagerate the severity of fluid loss.
The extension on the warranty for DRC IIRC you have to ask for and is only available for people who ask for it or have had to have shocks or DRC parts replaced but I will confirm this early next week if I can. Some dealerships will try and use the C5 RS6 DRC tool to repressurise the RS4 system but may encounter air in the system and therefore not properly recharge your system, they require the proper DRC II B7 RS4 tool.
I agree it is unfortunate that DRC is apparently not that reliable however given what it does and what high performace cars we have and when ou compare it to most other high performance cars then we are on average no better or worse off than if with an other marque.
One of the problems is the fact that there is so much conflicting information.
My system was charged to 14bar (not psi) and has been dropped to 13bar as it was being checked.
I have been told that the new tool (part number ASE 425 012 000 00 (VAS6209/3)) is only needed if you want to re-pressure the system without changing the valves. If you don't have the tool, you can still pressurize to the correct pressure (my dealer got 14bar without the new tool) and you can still fix the system, but you need to replace the valves. You can also check system pressure by locking off the valves without the new tool. Something you couldn't do with the RS6 DRC I system.
Audi have these tools in stock, but some dealers have not ordered them. But apparently they have sold 28 of them!! So someone has them out there!!!
And new shocks with improved seals have apparently been made available by the factory, and these are now in stock in the UK.
sandymat101
I have the same problem, got a June 07 avant from Stoke Audi with 15K miles in late November 08. I did'nt hear anything on the test drive but after reading about DRC problems on here I started to notice a knocking noise. So I jacked the car up and removed the wheel, there was oil all over the front offside shock, I had done 250 miles.
I had them replaced on the 23rd Dec but they didn't fit valves, it transformed the car but I can now hear a knocking noise from the same shock. I'm going to take a look tomorrow but I know what I'm going to find. Will this be bacuse new valves weren't fitted?
My knocking from the rear suspension was because they struggled to pressurise the system properly and when checked the pressure was only 7 Bar, nothing to do with the valves or the shocks. I wonder if you have the same because of low pressure / air in the DRC?sandymat101 wrote:I have the same problem, got a June 07 avant from Stoke Audi with 15K miles in late November 08. I did'nt hear anything on the test drive but after reading about DRC problems on here I started to notice a knocking noise. So I jacked the car up and removed the wheel, there was oil all over the front offside shock, I had done 250 miles.
sandymat101
It's got to be something like that because I've only done about 200miles since. I'll book it in, it's only going to get worse.
I'm wondering if they didn't fit valves because they haven't got the correct tool for the new design shock, I saw the job sheet it had 2 shocks, boots, nuts & bolts & oil as parts.
I'll ask to speak to an audi technician, the service bloke behind the desk didn't know what I was on about when I asked i they fitted new valves.
sandymat101
I have one question guys, since I am a new owner of an 07 RS4 with DRC PLUS. These leeks happen regardless if you have the standard DRC or the optional DRC PLUS? Because, if it's only happening with the latter (PLUS) and it will happen to me again (14 000 km front shocks changed) I am inclined to change to the standard DRC suspension. But if both fail, I think I will go for an aftermarket sollution (ohlins). Thanks
Marcus-RS4
In response to the original poster, everyone I've spoken to at Newbury Audi is fully aware of the DRC issue. It's disgraceful if they sold you a car with such a severe leak.
Every time my car's in for service work I get them to check the shocks just in case, and on last inspection the FOS one was weeping, but as rs4v8 said earlier, this is considered "normal". Trouble is, every little knock I hear starts me panicking now - if I was in any other car I'd just ignore the little noises!
Chris
06 Daytona RS4 Avant (B7)
I was the original poster and yes, it is bloody disgraceful. I haven't even had the decency of a response from Newbury Audi about this. I'll be calling them tomorrow god help them! What a shoddy bunch of...drcarrera wrote:In response to the original poster, everyone I've spoken to at Newbury Audi is fully aware of the DRC issue. It's disgraceful if they sold you a car with such a severe leak.
Users browsing this forum: Google Adsense [Bot] and 387 guests
