new rs6 owner with poss susp problem!
jayandrews
hi guys,i have recently bought what i thought would be my dream car-rs6 saloon.
upon buying it i have found that when driven really hard(foot to the floor) i get a sharp clunk from the o/s/r corner which feels like something is moving.it doesnt do it on normal driving but sometimes it will do the odd clunk when driving over bumpy ground quickly.
ive had a look around the shocker and there doesnt seem to be a bad oil leak,there is a sign that the shock may have been slightly weeping but no thing bad.
is this the sign of the suspension beginning to go or could it maybe just be a top mount?if it is just 1 shock,could it be sorted?
what are the tell tale signs of the suspension failing?
apart from this i love the car.
thanks in advance
jay
thanks in advance
jay
Cornishmoocher
- Top Gear
RE: new rs6 owner with poss susp problem!
DRC.
It's all Bollox.
ahh the dreaded DRC
RS6 Avant, black with black wheels, front S6 led lights, rear smoked Led lights, miltek non-res, miltek cat by-pass down pipes, ITG air filters, H&R kit with Arb's, MRC stage 2
Jay,
Don't waste your money on the DRC. Best thing you can do is bin it!
Good luck
Simon
Good luck
Simon
Current
1985 Ur quattro in Alpine White
Previous
2004 RS6 Mugello Blue Avant | Milltek Non-Res | Bilstein PSS9 Coilovers | Hotchkis ARB | Black Optics Kit | RS6+ Coloured Alloys (Sold but never forgotten)
2015 RS4 in Riviera Blue
2016 RS6 in Utopia Blue
2002 S3 in Imola Yellow
Previous
- Awesome_Andy
- 1st Gear
I found that braking hard (from warp speed) in a straight line was kinda fun. It's a game where you really have to fight to keep the car going in a straight line. It's an easy way to check the system pressure, if it squirms like mad you have a leaky DRC. Or if roundabouts become seriously scary things to go round quickly
Well, in my experience at least! Clanking rear suspension is also common on DRC failure/leak.
The problem is not only the cost to replace 1 shock, it's the getting the repressurisation right afterwards. That and the fact that the reliability of the repair is usually rubbish. Increasing the pressure back up to factory specs then puts more pressure on the other worn components that haven't been replaced. Mine failed within 1 month of it being "fixed".
The school of thought for most people is that if it's under Audi warranty get the DRC repaired, otherwise it's go coilovers as they are much cheaper and are reliable.
jayandrews
jayandrews
- WeaselRS6saloon
- 1st Gear
Unless something has drastically changed do not go to Sports Tech, not even for parts. See my previous experience (and other peoples) of these cowboys here -
http://www.rs246.com/index.php?name=PNp ... highlight=
My recomendation would be Unit 20 = Grizz
Regards
Kev
Regards
Kev
