I always pushP_G wrote:Do you pull or push. I always pull.....
How big IS the fuel tank on a B7 RS4?
- PetrolDave
- PetrolDave
- PetrolDave
If you can only get in less than 60 litres then you may have a problem.NGS521 wrote:no way is it 70 litres i rarely get in anything in above the high 50s and i always let it 'run dry' showing 0 -5 miles range.
BTW are you using the button in the filler neck? Pushing (or pulling) that lets you get an extra 5-7 litres in the tank.
B7 RS4 fuel tank is supposed to be 63 litres.
.pdf here: http://www.audiworld.com/model/
Don't know how accurate this is for that car though.. I'm supposed to have an 82 litre and I always seem to be right on that if I fill up from empty, so it's accurate on mine at least.
RE: Re: RE: Re: How big IS the fuel tank on a B7 RS4?
I managed to squeeze 70 litres in to my B7 a few times by using the air release button.
Golf R - with added MRC
Sprint blue B7 RS4 Avant - Sold
Ultimate Silver Nissan GT-R - Sold
Avus MRC 470 B5 RS4 Avant - Sold
PetrolDave wrote:If you can only get in less than 60 litres then you may have a problem.NGS521 wrote:no way is it 70 litres i rarely get in anything in above the high 50s and i always let it 'run dry' showing 0 -5 miles range.
I've never used the button! I will use that then report back, an extra 30 miles added to the range would be lovely. Thanks
So just to verify the tank must be some 70 litres as I have just run my RS4 to 0 miles on the DIS, and then did some extra 15 miles after thatso the dial is off the red line on the gauge but dtill going! Just filled up with... 67.5 litres for just over £60.
So anyone up for running their RS4 after the DIS reaches 0 miles until it cuts out to see how much extra in the tank there is?
Users browsing this forum: Majestic-12 [Bot] and 239 guests
