Possible to have the power outlet turn off automatically?
The cigarette lighter under the armrest stays on when the car is turned off. Is there a way to change it so that when I turn off the car, the charger will also turn off? I use it for my mp3 player which pauses/suspends when the power is cut. Thanks
tartan_rob
RE: Possible to have the power outlet turn off automatically
WHy not hard wire a power feed for your MP3 or buy the Audi docking station..?
2017 Kawasaki Z1000
2014 RS6
2014 S1
2014 RS6
2014 S1
- PetrolDave
Re: Possible to have the power outlet turn off automatically
Only by rewiring it.Spurian wrote:Is there a way to change it so that when I turn off the car, the charger will also turn off?
Better to do as Tartan-Rob says and add a switched feed for your MP3 player - I did that for my Pogo Alert.
You might be able to do it with Vag-Com, have a look on the Ross-Tech website
- PetrolDave
Re: RE: Possible to have the power outlet turn off automatic
You can't - 1,000,000% certain on that.pippyrips wrote:You might be able to do it with Vag-Com, have a look on the Ross-Tech website
RE: Re: RE: Possible to have the power outlet turn off autom
Would the dealer have to do the switched power feed? Also what is Audi docking station? I use a Zune which probably is less compatible than iPods.
- PetrolDave
Re: RE: Re: RE: Possible to have the power outlet turn off a
No, any decent auto-electrician can do it.Spurian wrote:Would the dealer have to do the switched power feed?
Users browsing this forum: Google Adsense [Bot], Zyox and 278 guests
